Solid State Generator via Electromagnets + Halbach Array
Started by void109, July 09, 2010, 01:50:53 AM
synchro1
Alot of magnet wire will stand away from the magnets. It might look more like sugar cubes between cans of tuna then the representations. Hi voltage wrap important. Maybe the cores could be made smaller.
Hope
Please continue this flux bender, perhaps end coils as well ...   and when you pulse you also create voids you can capture and reflect as echos.   Excited coils beginning at 5Kv  pulsed to 15Kv will give less resistance to flux paths.   Careful if you create a HOT CHASSIS not to ground yourself though.
TruthHunter
I see this "promising idea got dropped like a hot potato..
Flux switch can only work if the path is switched. This is more than that. Its substitution
of electromagnets for PM's. It simply requires too much power to switch the direction of the Halbach array.
Even for a standard(non OU) motor it won't make sense.
