Chalkalis Gravity Wheel
Started by teslaalset, July 10, 2010, 08:52:57 AM
Cloxxki
Quote from: FreeEnergy on July 25, 2010, 12:53:58 PM
nice pics/vid lespaul109, i think i understand now how this machine is suppose to work to produce free energy/over unity.fascinating idea!
Could you share? Most people do not understand.
Thanks!
woopy
hi all
just 2 cents, trying to harness the gravity power on a longer shaft. The setup seems to work, now lets do some measurement to see if Milkovic and Chalkalis together can do some usefull work.
any idea ?
Good night
Laurent
http://www.youtube.com/watch?v=lr69L9fJpY4
gyulasun
Quote from: lespaul109 on July 25, 2010, 11:40:17 AM
ok, tested my motor that has two coils. Each produces 8v peak to peak @ 300rpm. My drive motor needs about 3v @ 600mA can some one tell me how to wire both coils using diodes and/or rectifiers and caps to power my DC motor? Color codes are:
Coil 1: Yellow & Black
Coil 2: Red & Grey
thanks,
jake
Hi Jake,
The best circuit for you would be a DC / DC converter because it can have a 85-90% efficiency. It is basically a switch mode power supply.
However, first you can test an important thing: try to load your stepper motor's two coils output to see how much output power they are able to produce and how much drag it causes to your main motor?
Just build a full wave rectifier with two diodes like the first schematic in this link shows:
http://www.electronics-tutorials.ws/diode/diode_6.html
Of course your coils will connect to A, B and C points in the schematic (they will have one common point of course) instead of the transformer secondary and you have to find the correct phasing for your coils. Not shown in the that schematic a puffer capacitor arcoss the loading resistor symbol, you have to use at least a 470-2200uF 25V electrolytic capacitor to filter the output "half waves".
So if your drive motor needs about 1.8W (3V @ 600mA) then your stepper motor output also has to give at least 1.8W or a bit even higher...
Do not care how many DC output voltage you will measure across your resistor load, just test. Use the P=V2/R  where V=output DC voltage measured across the R load resistor you choose and vary.
rgds, Gyula
sm0ky2
Quote from: woopy on July 25, 2010, 04:10:54 PM
hi all
any idea ?
Good night
Laurent
for what its worth.... here is my idea
You could use the 2-stage lever oscillations to actuate a Solenoid.
Feed the energy into a capacitor, and use it to re-charge the battery.
Then it is simply a matter of monitoring the level of the battery to see what happens.
FreeEnergy
Quote from: Cloxxki on July 25, 2010, 02:13:51 PM
Thanks!
simple, the weaker small motor will spin in high rpm which will keep the pendulum rotating. now just attach a generator to the pendulum's shaft for greater output.
i am not sure if this will work, but it is how i understand the functioning of this system.
