The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
ramset
Slapper,
You slapped that together nicely!
Os has laid out a real simple concept here!
A gazillion meters or working surface,SWEET!
What you gonna drive it with??
On second thought I see its all there, In the bulb set up.
Hope it works!!
Chet
Thanks Grandma
slapper
didn't get a hint that it does anything. no bubbles. 8oz of draino in 16 oz of distilled. poured half the mix in the rigged up induction coil container.
so:
solution not saturated enough? it dissolved all the draino.
need it inside the coil - the way it was built for? maybe?
to much volume in the container?
pvc wall thickness to thick?
frequency? i'm at 250khz.
put the 80watt bulb back on - bulb still works fine, nice and bright.
gota go.
nap
we are not alone :)
stevie1001
Hi Oswald,
Thanks for sharing this info.
I have some questions and hope you can answer them.
Your details are: 5watts (5Vx1A) on a coil of 800 wraps of 22G.
As far as i understand electromanets, this setup is not a very strong magnet.
Still your claim is that this creates HHO from tapwater saturated with NAOH?
Steve
www.ionizationx.com
dutchy1966
Quote from: slapper on July 26, 2010, 09:41:15 AM
First of all a big thanks to Oswaldonfire for sharing this all with us. Hope this leads to more then on the OUPower board.
Slapper,
If I understand you right then your NaOH/H2O Solution is not inside the tube?? If it is not then it certainly needs to be in there because that is where the magnetic field is....
Please let us know if I understood this right, thx.
Regards Dutchy
mscoffman
Quote from: Hugo Chavez on July 26, 2010, 09:25:24 AM
...This would be freaking huge!
If it works it definitely would be.
An interesting true scientific experiment would
be to seal some magnolyser water inside a glass
container. Then ignite the hho and burn it inside
the top of the sealed container ala John Kanzius.
So that the condensed water drains back into
the bulk magnolyser solution.
If the power output was overunity and is always the
same then the excess energy is coming from ZPE.
And therefore the water molecules just fall apart.
But if you get an exponential energy extinction
curve it could be proven that the excess energy
is coming from the deuterium cold fusion reaction.
The energy will approach faraday levels in the
lower limit as it's fuel runs out.
This could become the classic scientific experiment
for proving cold fusion and you will have performed
it first.
:S:MarkSCoffman
