Working Magnetic Overunity Device - Magnetic Neutralization
Started by luishan, July 23, 2010, 11:08:52 PM
kcarring
I like the idea of a small gap device, for the pure and strict use (only) of keeping a Milkovic style pendulum in swing, giving it that tap... if even "not over unity" it could provide a thousand gallons of pump action an hour, with just a little "tap" made by a rubber ended piston fired electromagnetically.
hartiberlin
Hi,
GAP-power again has a new video out.
http://www.youtube.com/watch?v=CvkUIr8dv_k
Well done again in documenting,
but
Unfortunately he again makes the error, that he measures the voltage at the
coil and not uses the voltage from the battery.
He need to use the 45 Volts from the battery x average input current x 0.43.
This is the real input power.
Then compare this to his output power.
Probably the input power is greater then.
YOu can avoid this by using back iron cores from the magnet to the
end of the piston where the piston is the most away from the coil.
Compare this to RomeroUK device.
Regards, Stefan.
BasementExperiments
Looks like a great simple idea, i cant say much for the calculations, i find people spend a lot of time trying to figure out where someone went wrong than actually trying simple experiments to see if it's possible.
Does anyone know if others have tried replicating it?
If so, I would think once the machine is running it should continue on it's own.
It's a neat idea, I'm seeing this as just momentum of the return swing of the piston (magnetic push) that is likely stronger than the actual power it's taking to neutralize the field.
ill be attempting to replicate this over time out of curiosity, in the meantime ill continue to return here to get some other insight, thanks peeps
