FATHER OF WATER POWER CAR - Stanley Meyer's SECRET
Started by luishan, July 25, 2010, 01:46:19 AM
securesupplies
Here is the 2020 version with db 37 and  better labeling for implementation
Gerber and bom Attached
D :) :) :)
ID   Name   Designator   Footprint   Quantity
1   C1   100UF 25V   CAP-8*5   1
2   C2   0.1UF   CERAMIC   3
3   C3   220NF   CERAMIC   1
4   R1   3.3K   AXIAL-0.4   1
5   R2   1K   AXIAL-0.4   1
6   R3   8M2   AXIAL-0.4   1
7   R4   1M   AXIAL-0.4   1
8   R5   100K   AXIAL-0.4   2
9   R6   10K   AXIAL-0.4   1
10   IC1   4013   DIP-14   1
11   D1   1N4007   DO-41   1
12   Q1   2N7000   TO92 CBE   1
13   LED         1
14   P-12 PCB RELAY         1
15   DB-37 RIGHT-ANGLED CONNECTOR         1
16      Pressure switch 4 bar 60 psi 2 wire   https://www.turck.de   1
17      Pressure switch 6 bar 90 psi 2 wire   https://www.turck.de/attachment/d101929.pdf   1
18
vasik041
 Hello Securesupplies,
Thank you for sharing all these designs.
I am wondering, did you manage replicate complete system ? I mean run car or some engine on water ? How efficient it is ?
Thanks,
-V.
securesupplies
the Pressure Regulator Circuit controls the  skew scale of up and down of gas production against fuel line pressure
here is the gerber
Dd
securesupplies
3 wire sensor different from auto start which is 2 wire
securesupplies
ID   Name   Designator   Footprint   Quantity   Manufacturer Part
1   P1   20K   TRIMMER   2
2   R1   6.8K   AXIAL-0.4   1
3   R2   2.2K   AXIAL-0.4   3
4   R3   51K   AXIAL-0.4   1
5   R4   39K   AXIAL-0.4   1
6   R5   5K1   AXIAL-0.4   1
7   R6   10K   AXIAL-0.4   1
8   R7   100K   AXIAL-0.4   2
9   R8   3K3   AXIAL-0.4   1
10   LED1   LED   5MM   1
11   C1   0.1UF   DO-41   6
12   IC1   LM324   DIP-14   1
13   P2   10K    PRESET   1
14   D1   4148   DIODE   1
15   Q1   BC547   DO-41   2
16   DB-37 RIGHT-ANGLED CONNECTOR         1
17      MPX5500DP   SENSOR-TH_MPX5500DP   1
