FATHER OF WATER POWER CAR - Stanley Meyer's SECRET
Started by luishan, July 25, 2010, 01:46:19 AM
securesupplies
QTY Full   Board Reference Full   General Description   Value
      IC CIRCUITS
5   A23   LM731P OP AMP
   A24   LM731P OP AMP
   A25   LM731P OP AMP
   A26   LM731P OP AMP
1   A27   4046-PWR    4046 - PHASE LOCK CHIP
4   A28   4017 DECADE COUNTER
   A29   4017 DECADE COUNTER
   A30   4017 DECADE COUNTER
   A31   555 CHIP TIMER
   A32   LM731P OP AMP
   A33   LM318 OP AMP
1   IC1   4001N   QUAD 2 -INPUT NOR
1   IC2   4066N   QUAD BILATERAL ANALOG SWITCH
2   IC2   4001N   QUAD 2 -INPUT NOR
      CAPACITORS
1   C1   470nF
   C2   100nF
   C3   100nF
   C4   100nF
   C5   100nF
1   C6   10uF   35 volt polarized capacitor
1   C7   47pF
1   C8   300nF
3   C9   1uF
   C10   1uF
   C11   1uF
   C14   .1uF
   C15   100nF
1   C16   35nF
   C17   10uF   16 volt non polarized capcitor
   C18   100nF
   C19   100nF
   C20   100nF
   C21   100nF
   C22   100nF
2   C23   .1uF
13   C24   100nF
   C25   100nF
   C26   100nF
   C27   100nF
2   C28   10uF   16 volt non polarized capcitor
      Diodes
1   D1   1 KV 5 AMP SPEC
1   D2   1N405
3   D3,D4,D5   1M4001
2   D6,D7   1N4148
      Transisitor
3   Q1,Q12,Q16   2N2222
2   Q6,Q8   2N3906
1   Q7   2N3904
      Resistors
   R1   10K
   R2   10K
   R3   10K
   R4   10K
   R5   1K
   R6   1K
   R7   470K
   R8   470K
   R9   10K
   R10   47K
   R11   22K
   R12   1K
   R13   470K
   R14   1K
   R15   470K
   R16   470K
   R17   ??
1   R18   440K
1   R19   2.21K
1   R20   2.21K
   R21   100K
1   R22   1M
   R23   10K
   R24   10K
   R25   100K
   R26   100K
   R27   560K
   R28   27K
   R29   4.7K
   R30   10K
   R31   10K
2   R32   22K
   R33   2K2
   R34   470K
   R35   2K2
7   R36   470K
3   R37   2K2
5   R38   1K
2   R39   47K
1   R40   10M
10   R41   10K
   R42   220K
2   R43   220K
      Potentiometers
1   Potentiometer  Panel Mount Through Hole   50 kOhms 500 mW (1/2 W)   https://th.mouser.com/ProductDetail/Honeywell/392JA50K/?qs=%2Fha2pyFaduhDOCKt20U9cFcOvaq0S9kP20pqEwlrYeHG1yY04GUTjA==
1   FREQ - ADJUST     100 K 3296 TRIMM RESISTOR FOR 4046
1    POT 1      50 K  CONDUCTIVE PLASTIC RESISITOR
1    POT 2       50 K  CONDUCTIVE PLASTIC RESISITOR
3     MANUAL       50 K  CONDUCTIVE PLASTIC RESISITOR
      LED'S
1   OSC LED           GREEN   5 mm DIFFUSED
2   LOCK ON          RED     5 mm DIFFUSED
      IC SOCKETS
6   8 pin   ic socket   8 pin    ic socket
4   16 pin    ic socket   16 pin    ic socket
3   14 pin    ic socket   14 pin    ic socket
      TOGGLE SWITCH
      on on 2 position   10A 125 VAC
      on off on 3 position   10A 125 VAC
      test connectot
1   bnc test  connector pcb through mount   bayonette fitting
      Fuse Socket
1   fuse mount fuse holder    through hole black
Johan_1955
Hi Daniel,
Did hear from some of mine partners, they are from Belgium and knowing you,
that you did find 8 years ago a Big-Investor from WhiteRussia, is this true and working?
What is the status of your build currently, maybe a movie?
Kind regards,
Johan
securesupplies
The world is building not one person but many thousands of builders.
The People who know and protect the technologies do not need any publicity or discussions.
Suggest you simply study the ways to build and implement no conversations are required here as this is
a charity thread to share knowledge.
