Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
david lambright
tHi-
So far, I have been a lurker in this thread, but also an avid reader of the forum and following David's YouTube vids. I KNOW that he is correct in describing what he feels / felt, while experimenting with his device.
Here is my experience: I don't have resources (time, mostly) to build David's rig. So I built a small 3" PMH which consists of two semi-circular pieces of spring steel, filed on the ends, to make a slightly oval profile. I used about 25 wraps of copper wire and energized with a car battery. Both halves are magnetized together (locked). The overall shape looks a bit like an egg. (There are no heels or legs sticking out.)
I mounted this to a circular piece of plastic with zip ties, used a carriage bolt with a hex-nut - on the underside of the disk - and place the bolt in my variable speed drill and spun it at approx. 500 RPM.
Using a variety of stones that I have collected over the years I tried every one (including Amethyst geodes which contain quartz) and felt very little - if anything.
Then I tried a green rock I have which is very heavy for it's size which definitely has a great deal of crystalline composition (might be a form of Serpentine). Using this rock I DID feel a PUSH in my hand which varied depending on how I moved the rock in relationship to the spinning PMH. Looking closely at this stone, it does have at least one surface which could be viewed as a "cavity" (CAVITATION?) that is a finger-nail sized depression in the surface. It was near this surface at about 10 degree angle to the spin plane, that provided the most feedback (although I sometimes did feel a similar push using a pointed end of the stone nearly touching the "axle."
Comment to Dave: Hang in there, buddy, I know you are right - check your geode for cavities / surface features that could be somehow collecting and amplifying the effect.
I also noticed that Dave's rig is without one feature that Ed's rig included (and I have seen it in other's pictures on the forum) which is the "Quatrefoil" shape (PMH?) on the top edge of Ed's machine. I would theorize that adding a part shaped like this on Dave's device may amplify or "tune" the output??
I am also in Oregon, I live well North of Dave, but both my wife and I have felt a clear "push" when moving this stone over the PMH. I am tempted to take it to his "neck of the woods" and try it there. I also saw (with my eyes) some "interaction" between the stone and the PMH but I doubt it could be filmed and I am trying to decide if I really saw what I believe I saw.
Also, I feel a little odd when I am around the PMH for extended periods of time. I slept with it on the night-stand last night and slept very well, but woke feeling very off - something  in the pit of my stomach???
-Van
his was posted yesterday......... david
Mk1
@all
Hello everyone , thanks for your patience .
I have this Ed clue that illustrate my point .
Look at the Florida table chair spacing and dot on the flat top .
I was right about looking east ...
@scotty
I will take time to answer all your citation , and explain my views on the subject , simply stating that magnetic current means electricity doesn't work for me , i think he speaks about the magnetic reaction in iron induced by electricity , you know a transformer core dose not hold electricity but magnetism , we have a really basic understanding of how to use it in its magnetic form .
Once i make the reveal , you will all see how simple it is ...
Mark
Mk1
@all
I would have loved to make this step by step , with some video example's
I think people are better one step at a time , but i ask you to jump 15 so there we are , i hope this is simple enough ...
@scotty
I bet you can test it ! see the huge transformer at the site of the wheel , it can only slow the wheel unless it part of its function , Ed used magnetism without converting it to electricity , the hard part now it to get good soft iron .Steel will not be useful here because it doesn't become a efficient magnet like soft iron .
Mark
Time as almost run out , i can't do it all by my self , i will try anyway ...
Edit , i added a picture where you see the magnet wheel on a pendulum reference to the 2 forces ...
david lambright
i believe Ed heated those segments past their Curie point before he assembled his wheel so that the iron was "fresh", with no permanent magnetism....scotty [loadstone?] shows that a PMH can be locked with a single long wire that goes through the center of the PMH, not even wraped around either leg!...you need to use a larger wire but it does work.....i can lock steel to ferrite with one wrap of wire... YouTube - david showing ferrite+steel PMH ...i have used a cap from a camera flash to lock a PMH also but i did not notice any difference in the strength of lock .....scotty said with a larger device, the strength of lock varied with input, voltage, amps etc. up to saturation....i think what i need to be looking for is material that can be super- saturated ....possibly an alloy or an oxide mixture...magnetite sand from china? ...the oxide core devices work very well, with plenty of visual radiations [vibrations?] and other super -magnetic [making all materials feel as being push/pulled magneticly] forces, radiating from these devices....replicators are seeing/feeling these SAME things...little by little we are figuring out EXACTLY how to reproduce this radiated wave, every time....for all replicators....this is something very different yet following some of the same sets of rules as electricity or magnetism...we all heard about the plastic film factory and the "wall" produced ...nothing there but an area made "solid" , by an invisible source?....this makes sense if these waves can add density or take the density out of a material ....in my first videos i am spinning a 14 pound quartz geode, with my fingers, it feels as though it has lost some of its mass and feels light. at this same time there is what looks visually like an interference pattern....i believe when these waves interfere or cancel,is when these effects are at their best....in affect, cancelling out some of an objects mass/inertia/gravity, it is all the same thing...the static wall shows us that something can cause invisible density or mass?...i propose that if a density can be manufactured, then so can its opposite, that can take the density/mass out...david
