Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
IotaYodi
QuoteRadio never needed electricity in the first place ... like fox hole radio
I see what your saying Mk. The statement made that he ran the radio off his system is still in error. The station broadcasting the frequencies would run it. The radio itself is a receiver coil. The electromagnetic frequencies pulled in by the copper coil would induce current into the coil. Im still seeing that as electricity.
Is this block a coil?
What I know I know!
Its what I don't know that's a problem!
Mk1
Quote from: IotaYodi on November 13, 2010, 07:58:29 AM
How much energy you need to broadcast ... Is a NS coil a receiver ...
The transformer you see can supply electricity , but tell ma what a huge chunk of iron dose to a magnet wheel ? It stops it! Not efficient by design ? Even worst with the coil loaded . Ed was working alone what was turning the wheel .
The coil is there for something else , i hope you at least looked at my tread.
We know electricity , we know the primary and secondary are not directly connected , so how come electricity come out at the other end , because it became magnetic current inside of the core , we need magnetism to make radio wave .If i found a way to make magnetism why would i bother with electricity . We usually use electricity for it but that is not needed .
He was working alone , and he never told anyone he used radio , for anything but entertainment . ???
Mark
IotaYodi
QuoteHow much energy you need to broadcast ... Is a NS coil a receiver
Not much at all. Yes the ns coil can be a receiver when tuned.
QuoteEd was working alone what was turning the wheel .
I only see 2 possibility's. He turned the wheel to charge something up or it was self reciprocating once started.
I live in Florida and went there once but thats been over 40 or so years ago when I was about 15 years old. I may have to make a trip there to get a better overview and feeling on it.
What I know I know!
Mk1
Quote from: IotaYodi on November 13, 2010, 09:40:19 AM
What ever ...
You did not even look at my tread ...
NS coil is a transmitter  >:(  , why do you think you get a visit from the authority if put a NS coil in the ground ?
There are 2 forces making the wheel turn gravity and magnetism .
Sorry you can't see that.
Mark
scotty1
"The reason I call the results of North and South Pole magnet's
functions magnetic currents and not electric currents or electricity is the electricity is connected too much with those non-existing electrons. If it had been called magneticity then I would accept it. Magneticity would indicate that it has a magnetic base and so it would be all right." Ed. L
It's pretty clear yes?
Magnetic current IS electric current.
When the individual magnets enter the coil they are in bulk form....the coils job is to divide the magnets into small path's....that is your electricity.  ;D
Let me show it again.
If you have a copper wire in an E/W position with pos current entering from the East and neg from the West, then a  magnetic needle hung above the copper wire, with it's N pole at the lower end, will be deflected to the North.
If the S pole of the needle is above the copper wire it is deflected South.
Now Ed wrote "The hanging magnets that hang up and down, they show that there is motion inside the bar.  Hold the perpetual motion holder North Pole magnet or pole end East and South Pole magnet terminal or pole end West, now raise it up slowly to the South Pole hanging magnet, then you will see the South Pole hanging magnet swinging South. Now put the perpetual motion holder under the North Pole hanging magnet, raise up slowly, then you will see the North Pole hanging magnet swinging North.  This experiment shows without any doubt that the North and South Pole individual magnets are running in the same direction as those in the copper wire, which came out of the car battery, and in both instances while the magnets are running ahead in whirling motion they used the right-hand twist."
So, again everything is clear yes?
BTW, I think only a good "wrought iron" will show the results.
Wrought iron has a laminated structure so it throws out the magnets much more.
Scotty.
