Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
Hope
So this is my take on Ed's Wheel.  Notice how the magnets are pointing outward and the center of the bars are pointing inward?   I believe he was making a zero point in this center of magnets to attach to so he could draw from the sea of energy.  David I believe what we are seeing on your wheel of u shapes is the creation point of "all" which is near the "zero point" (destruction point) but travels outward till creation happens again.  See Walter Russell charts to understand better.
7redorbs
Hello,
I have studied Edward Leedskalnin for some time, and the holistic teaching. Somebody mentioned about induction being a factor in the faster than light velocities of the magnets, and it was suggested that it was quite a troublesome deal, intercepting a packet of data/light or a physical magnet, that travels in precession to the trigger.
In any case, it was suggested that there would be a great difficulty in dealing with this, in a 'modular' 'singular' device this would be true (as afterall predicting the time the flow of the current appears is not a simple feat in terms of the induction relationship, and indeed the quadrature of the induced wave).
In this case we have the newtonian f1 force, and the reactive newtonian f2 force, and the way around, the problem presented by the faster than light, a larger assembly must be built. This might be compared to the likes of a wave guide, such as demonstrated in the works of Nikola Tesla and Oliver Heaviside.
I have more documentation if you are interested in PDF format quoting directly Jim Le Surf's work and theorising the applications of negative resistance oscillators, their meaning/importance in electrogravitics and how the f2 reactive force,  beign aligned with the newtonian f1 active force would result in a conservational runaway, whereby the balance of the force is being longitudinal directed from the transverse.
Edward Leedskalnin would consider the "Longitudinal" 291,000mi/sec (or ratio of C therafter) wave form propogations to consist of "horizontal" or "vertical" only force, and the transverse sinusoidal wave (that features a 90 degree relationship) consists of BOTH horizontal and vertical. Here we have the demonstration that Eric Dollard, Nikola Tesla and Oliver Heaviside importantly makes, including that of Keeley and Lopez, there is a CLEAR seperation in the TWO fields that dictate the operation of a transformer coil.
In this case, the maxwell theory in the state it is (without quaternions or the original derivatives), is woeful , and limited to second order differentials only, that make the erroneous and deluded assumption that the field vector of dielectric longitudinal and transverse magnetic are one, indeed, the works of Steinmetz in R. Kline's book "Steinmetz: Engineer and Socialist" revealed that they were seperate and independent forces which formed the "antithesis" of each-other. As Eric Dollard rightly points out in his SFTS (San Francisco Tesla Society) lectures tha thave been recently leaked onto youtube, the rule of law in space is different, and the growth and diminishment of waves is too.
Interestingly it was Steinmetz who discovered that high voltage, high frequency transmission lines would "asymptotically" increase their voltage with distance in AC transmission lines, this of course presented a rather difficult problem for the proper regulation of electrical circuits, one of which Steinmetz worked at length on, and it was Heaviside that worked a great deal on the equations of Maxwell, and  him too that simplified them under a significant pressure from the scientific community. Science as it exists today uses a delusive Maxwellian theory based on a perfect iron core, and the incorrect and broken assumption that the dielectric field exists "as" the magnetic field, "as one", in truth, and practical experimentation, such as the work by schauberger, grebenikov and tesla, shows they are not, and are seperate and distinct antithesis', e.g. that the cavity structure effect, and such technology represents a very real and exhaustive conclusion as to the nature of universe, life, and more, but it exists mostly beyond 2nd order differentials, Steinmetz developed an engineering/graphing language to represent AC waves, imagine a 3hz signal and a 7hz signal, in an AC phase system. I think it's clear where the peaks and troughs appear determines the superposition of the waves. Wave guide concepts important to the TMT, electromechanics, electromagnetics and electrogravitics, I would claim.
Smokey, a post I read at the beginning of this thread inspired me to share everything that I know as best I can, because it seems there are a few good men on this planet, that are willing to do the same, I shall step forward and try and give it as best as I can. There are radiation that is emitted (dot product expansion), and there is radiation that is absorbed (dot product compression). There is an expanding force and a contracting force (this is remarkably like the longitudinal force).
Gravity reveals something about electricity that is surprising. Take a metal head hammer, and smack it against a piece of metal on the planet earth hard enough, and you will get a spark, the size of that spark determines the amount of volts, and those volts were determined by the mechanical force of the hammer hitting the metal, and the resistance of the metal from the hammer (newtons laws), we see that not only does mechanical energy produce electricity, but electricity can produce mechanical energy (the difference is that between a motor and a dynamo), we also see that gravity produces the mechanical energy, otherwise there would be no weight to the hammer, and thus no f1 force, and thus no f2 reactive force.
Without gravity magnetic action, there is no mechanical magnetic action, and when there is no mechanical magnetic action there can be no electrical action, and where there is no gravity magnetic action, there can be neither.
Take a meteor or an asteroid in the vacuum of space, traveling at a constant speed, upon approaching the earth it is said to "Accelerate" as it is "caught" in the "well" or "wake" of the planets so called 'mass', regardless of mass or magnets causing this force we can see that the asteroid has ENERGY STORED, and the thing that allows the ENERGY STORED in the constant initial velocity of that meteor or asteroid (regardlesss of the acceleration caused by gravity), will require the waveforce of gravity, and the resistance of the "ground" to release that energy.
Simply with nothing to push off there is no f2.
I hope that this risk, and this work is worthwhile and one day might benefit humanity,
I also would like to say to smokey that I have the full original copy if you are still looking for it.
Note: I have been aware of this thread for sometime as it linked to my articles that I wrote at conspiracy.co, and since I have been silently watching (although not reading all of smokeys stuff, wow your good ;) ). Might I suggest, although a bit crazy, my work puts a new and interesting direction into the holistic works of the field of Solomon, the great work, and the trinity energies and CROSS PRODUCTS we deal with. Look into the sky like I do and you will see the Aether, it's "Y" factor.
I would say this, moving a mountain is no more complicated than inducting a field into an assymetric ground point thereby causing negative rotation in an unbalanced way, moving the mountain feet, or even miles. This is akin to the claim that tesla made about "cracking the earth in two", he was refering to the rotary magnetic field, the cumulative TMT effect, and the iron magma in the ground, to which pressure could be overtly forced.
It is of course no wonder that people that work with this are attacked, given such implications. I cannot communicate enough how lonely this work can be, it's burden, or how the heart weaps at the lost efforts of those such as Eric Dollard, Wilhelm Reich, Chris Carson, Scotty, Smok3y, and many others,
I wish things were different. Unfortunately they are not. Look at the work the Nazi's did with the Parametric Transformer, and the tight locality to the emergence of the 'electron technology' and the emergence of world war scenario's. Surely we would be fools to think that it was mere co-incidence, fools to think that the ancient pyramid builders civilisation whose word the Egyptians discovered and preserved in part - did not in part destroy itself, to account for the rather large gaping hole between electromagnetics and the truth about magneto dielectrics.
The fact is I am not as smart as I would like to be, but maybe that is just as well, in that, just as well I couldn't listen to the tripe I was taught during Q.E.D lessons that the "resistance in the wire" changes.
The thing that fascinated me was how I was explicitly told that measuring the voltage or amperage in a wire 100 times was "more accurate".
This truly is a great madness more than anything else, as I child I could not emphasise my bemusment, as the voltage and amperage was the physical value that was measured each time. As a musician it was not heard for me to see, that in this case "TIME" was the variable that changed. Using such techniques we merely measure the 'average' of the dielectric , the magneto dielectric, and the CROSS PRODUCTS.
I may have been infantile and stupid as a student, but today I am bold and good-sighted enough to point out to you, that this averaging of the varying resistance is a madness that physically removes the evidence of cross product fluctuations for the aether. From my exhaustive researches, it appears this was done because the Aether itself was very hard to account for, indeed, as in negative resistance oscillators, it is very had to account for the "exponential increase in energy" , and the 'source' of the reactive component, nonetheless, both exist, and it is the source of the reactive component (that comes from somewhere in the universe due to the OSC) that actually inhibits the so-called negative resistance oscillators, which by ordinary maxwellian theory alone, suggest theoretically they will cumulatively oscillate given a constant excitation whereby the losses per second are less than the constant excitation.
I'm sorry, I do waffle a lot.
Best,
A
CompuTutor
It is so refreshing to read a long entry like this that hits every nail on the (proverbial) head.
Just to read that, and not find dozens of errors is refreshing in the very least.
I don't compliment often, as you all know...
7redorbs
Quote from: CompuTutor on March 28, 2012, 02:54:28 AM
In the unlikely event that you might be referring to my post, might I thank you sincerely for your kind words, I did not expect it.
I wrote some music (notice the representation of the waves I use in the music to mimic a TMT (impulses per width, per time) (about 3 minutes 02). The note length per bar is reduced by n/2, and added a video presentation piece with some of commentary from Dollard and Wilhelm Reich, I think it is quite accurate, in terms of conveying to the original man where he must start, "to go on to explain" the "different set of dimensions", "velocity of light is simply an expression of the radio of energy to mass, which is a constant - not a limit".
http://www.youtube.com/watch?feature=player_embedded&v=vae8lCC_T2c#!
I hope that someone will, at sometime in the future, listen to this recording with great respect. .... That they all without any exception, are against , I say, against what I am doing. Every single one of them, slightly interferes with my effort, prophecies out, rolls out, flattens out, that one thing or another , whatever it may be, to diminish my efforts, no, to diminish the effects of my efforts, to block out the sharpness and acuity of my thoughts, to reduce to rubble and nothing, or nothingness" - Wilhelm Reich
7redorbs
Hey was that reply talking to me? :)
If you want to discuss stuff more I'd be happy. I just performed some interesting experiments with magnetic current that catches the sparks rotating with the RMF , which is interesting, to say the least, and slightly confirmatory.
If only the transformer physicists knew that the reason their coil's geometry wasn't because of the left hand rule or proper 90 degree induction at all, but because the physical magnets in the wire themselves are spinning around.
That is why the best most efficient transformer will be circular, because the magnets are spinning around, and it has nothing to do with the electron rule itself, but the actual rotational movement of the substance moving around in an iron core.
I believe this is what Oliver Heaviside was researching in some depth, as well as C. P. Steinmetz (hysteresis) , maxwell quarternion's etc.
It's really quite simple, once you're able to live with these two facts.
1) Waveforms can travel at faster than C and 'merge' to form what we call C, this is the ratio of energy to mass (a cross product balanced conversational exchange. )
2) The earth itself is a giant magnet, and space a giant vacuum capacitor, and any current running in any wire, will be affected by the more dominant magnet. A motor that rotates with the sun is not a new Idea, both I and Tesla suggest it, and both I and Tesla insist at the detriment of our reputation, that other previous civilisations had, and were able to achieve such a thing either through necessity or the capacity for their observation of nature and magnetic and electric currents.
In any case this should be enough to completely transform most peoples realities, as we still believe in the delusive electron theory, when in fact the magnets was the substance pushing the 'electrons' around all along, and the transformer is only round to allow the most effective transmission of that magnet substance, if it leaves the wire the resistance is much higher, however simply the magnetic substance prefers to rotate; that is the magnets in the transformer,  regardless of the fleming right hand rule, wish to spin, and if they cannot spin, then electrons cannot be made. - (in fact the fleming rule should be thrown away for this particular area) because any other geometrical shape of the wire, will affect the magnets traversal, not the total induction (because essentially they are whirling magnets in circle like vortex fashion) - and the wire being anything other than that, will cause the magnets to escape, or to reflect. This means without doubt that it is the traversal of the magnets that is responsible for the total induction, and the total induction is responsible for the total power. Note whilst the scientists are half right: that the total induction by a magnetic current is responsible for the total power. They missed the secret of the pyramid builders, that the total induction is related to the total magnetic current; since our Transformer is magnetic, and since the electricity is also magnetic, and since the earth is magnetic, and all of the planets, proper use of these fields will require alignment on every imaginable axis.
We just need those balanced products to be unbalanced. We just need energy, or light from somewhere, on one side, and the other side will move towards it, like the planets. Remember you do not ever see the sun, you see it's reflection on the atmosphere, and that should be enough to tell you about magnets, time, and the disconnected reality,  between what created that sun in the sky (transverse reflections off non vacuum atmosphere) and what was actually there (the longitudinal component of the sun that is not visible to naked eye without reflection, because it's speed exceeds that of light).
That is probably enough ranting on,
I know I do not explain perfectly, but, I do explain. Which is more than I can say for the scientific and engineering statuses of the explanation for transformer core's. As the great Tesla once said it reads like "delusive fictional work". I cannot say anymore, because apparently for the last 100 years our best electrical engineers, including those at RCA have known that the alignment and subsequent rotation (position) of the planets relative to the earth affect quite clearly the transmission lines that they maintained.
Of course the ignorant, stupid , arrogant, physicist, who has been taught it all works like x y and z, and is not required to maintain electrical circuits with an accuracy that reflects the original maxwellian reality of quaternion (non second derivative) can continue to live inside his delusive 3 dimensional universe, and they can ignore all of those magnets axis reacting with eachother, or pretend that they understand it well, or worse that the planets and their magnets , they are isolated and apart. They are wrong, so for the rest of us we'll be picking up where the Pyramid Builders left off, and, where the Egyptians started. We'll be seeing transformers that  with a multimeter end to end, the voltage and current show 0, but inside there is so much electricity being made from the square root of -1 , one might need to be careful not to permanently terminate ones life.
Remember how thick those bits of chains were, what do you think the maximum rating for them is?
You should know with 12Volts and a high amperage car battery I'm getting sparks the length of my arm
Best,
A
