Energy Reciever design
Started by Diode, April 17, 2006, 09:11:05 PM
hansvonlieven
G'day Lanka,
You were wondering how to get some pure Sodium (Natrium in German and Latin). Some scientific supply houses sell it in small quantities but this is expensive and they probably wouldn't sell it to you because it is very nasty stuff.
If you really need some you have to make it yourself. Sodium Chloride (Kochsalz) is not a good starting point, Caustic Soda (Sodium Hydroxide NAO2) is much better.
All you have to do is to get rid of the Oxygen and you have the metal. This is not as difficult as it sounds.
You will need two carbon rods and an electric welder, some sort of small ceramic vessel and some ingenuity.
You must mount the carbon rods in such a fashion that they can maintain an arc in the bottom of the vessel using the electric welder as a power source. Once the arc burns you simply add the Sodium Hydroxide to the vessel. The arc will rip the oxygen from the sodium Hydroxide and the metal remains. As long as the process is going there is no real danger as the space on top of the reaction is a reducing atmosphere.
The moment you stop things become tricky. On no account must the metal come into contact with the air or any moisture. Even the small amount of moisture in the air can trigger a violent reaction.
The metal is a white silvery stuff about the consistency of cheese, you can cut it with a knife. It is usually stored in a jar full of oil. Any contact with water will set off an explosive reaction combining with the oxygen in the water to form Sodium Hydroxide and releasing Hydrogen gas.
If you ever are tempted to try this please read a lot more on the subject and familiarise yourself with the necessary precautions you must take to ensure your safety. Contact between the metal and the skin must be avoided at all cost as very nasty burns result, safety goggles are an absolute must as the smallest bit of the metal hitting your eye will destroy it.
As I said, it is nasty stuff.
Hope this helps.
Hans von Lieven
Grumpy
Method and Apparatus for Converting Electrostatic Potential Energy
        -Frank Edwards
Localjoe
Hey i posted a very similar idea in the other batteries section and trees have a huge impact on current so try that too but my post is left hanging where i need some ideas for a circuit that would collect this energy and step it up a little. http://www.overunity.com/index.php/topic,3500.msg55406.html#msg55406 we should collaborate together.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Pirate88179
I am working on this even as we speak.  Everything I have read on this (Google: Earth batteries) speaks of not only north/south alignment but the angle from the bottom of the rods in the ground need to match the declination and can be measured by using a dip needle.  I am going to start by attempting to light a very small red LED and then may progress to using a capacitor to see how much it might charge it.  Then, I want to attempt an array and wire them in series to see what max volts might be achieved.  My electronics background is weak so I will need input from you smart folks here on this forum.
sm0ky2
This "ground battery" is nothin more than an electrochemical battery.
utilizing electrolytes in the dirt/soil.
you can achieve the same effect with the copper + steel/zink in a bucket of saltwater.
personally, i think it is salt that does this, but ive had a geologist tell me there are hundreds of other minerals in the ground that could be equally responsible.
while i haven't performed this experiment myself, i propose that the power (Volt * Amp) is going to be proportional to the surface area of the two electrodes. it should be stackable in both parallel and series to create a battery of any size, but one would deductively conclude that this will eventually deplete the ground of electrolyte, so this would have to be replenished over time in order to sustain a very large array.
:::as to the effects of the magnetic allignment, it should be viewed as not a "boost" from the
   magnetic allignment, but rather a reduction in the back-EMF caused by perpendicularlly
   crossing the earths field. which decreases the power.  So, alligning it with the field causes
   almost no back EMF, and essentialy lowers the resstance of your circuit, allowing for more
   efficiency.
