sound and vibration, inside thomas trawoeger's pyramid.
Started by 11:11, July 29, 2010, 08:17:23 PM
11:11
http://www.youtube.com/watch?v=aoQohr4k4Rg
this inventor used wind,
to make a magnet vibrate,
inside a wire coil.
to create wattage,
inside the wire coil.
it would have been more efficient,
to turn electricity into sound, like a radio does.
and have the sound shake the magnet back and forth.
so that the magnets magnetic field,
is inducted into the wire coil.
it is clear that in TT's pyramid,
the magnet was shaking back and forth,
due to electricity being converted into sound.
i suspect that the magnets poles were facing up and down.
so that when the magnets magnetic field was inducted through the copper loop,
the effect was that one pole of the magnetic field,
passed through end of the wire coil,
and the other pole of the magnetic field,
passed through the other end of the wire coil.
so that TT's magnet,
was aligned with TT's wire coil !
EXACTLY like the magnet and the wire coil in the above video were aligned !
like this:
                   - TT's magnet  +
       <---< 8 gigahertz of shaking! >--->
                   - TT's wire coil +
i took a close look,
and it appears that the pipe that TT's magnet rested on,
was mainly being held up,
by the thick copper band,
that was attached to the lower capacitor.
so that the magnet and its small segment of pipe,
were able to mostly move/vibrate freely,
of the copper loop and its wire coil !
                         pipe
                    -  magnet +
    <---< 8 gigahertz of shaking ! >--->
                    - wire coil +
                    copper loop
11:11
a DC electricity buzzer,
could be used in place of a computer fan ?
the DC buzzers at radio shack,
put out high frequency AC sound,
even though they run on DC electricity.
i imagine that a small buzzer,
would have a very small amperage requirement.
yet could still severely shake up the wire coil.
could induct into the wire coil.
especially if you placed the buzzer right next to the wire coil,
at point blank range.
maybe there was the equivalent of a buzzer,
inside the great pyramid of giza ?
the ark of the covenant,
was made of positive gold,
and was full of sand,
and was attached to a diode ?
and the copper loop was all of those things.
if the ark of the covenant,
was being used as a high frequency buzzer,
than that would explain that old legend,
about "the voice of god",
coming out of the ark of the covenant !
because the ark of the covenant,
worked like an electronic speaker,
to create sound !!!
fritz
Quote from: 11:11 on July 30, 2010, 09:57:22 PM
Radios and loudspeakers are known for their lossless and high efficience transformation of electricity into rocksolid soundwaves.
Air itself is the ideal media to transfer pure energy worldwide to almost unreachable regions.
Tesla new about that.
All his electric stuff was just a trick to hide his ultimate goal:
Transfer of energy with soundwaves.
Edward Leedskalnin could move his favourite stone carved maid by simple singin his favourite country song. The resonances within that stone puppet released that electrostatic potential of the quarz inside the rock.
wow.
11:11
Quote from: fritz on July 31, 2010, 05:06:19 AM
wow.
the purpose of the buzzer,
is to vibrate the wire coil,
so that the magnetic field of the magnet,
can induce into the wire coil,
to create electricity.
it is less about creating sound,
and more about turning electricity into physical shaking.
a buzzer would use less amperage that a computer fan,
would not have spinning parts like a computer fan,
and would create far less eroding friction than a computer fan.
which is why for these purposes,
a buzzer would be more efficient,
but i'm sure that you knew that.
11:11
1:
any material with a crystal lattice,
is at least somewhat piezo electric.
because when electromagnetism is passed through the crystal lattice,
the magnetic bonds between the atoms,
expand and contract.
changing the shape of the piezoelectric material,
in a way that moves air pressure (sound).
there for,
the drywall triangles on TT's pyramid,
are piezoelectric.
2:
sound is electromagnetic.
so when sound touches the drywall triangles,
create their own sound.
but the sound of the drywall triangles,
is directly opposed,
to the sound that struck the drywall triangles.
so the sound that activated the drywall triangles piezoelectricity,
echoes back into the middle of the pyramid.
but not only does the first sound echo into the middle of the pyramid.
the sound created by the drywall triangles piezoelectricity,
ALSO echoes into the middle of the pyramid !
with the result being more sound sent to the middle of the pyramid,
than there was sound that left the middle of the pyramid !
3:
TT had what amounted to a microphone,
in the middle of his pyramid.
he had a wire coil,
that was physically shaking back and forth,
inside a magnetic field,
to create electricity inside the wire coil.
4:
the build up of sound in the middle of the pyramid,
causes the wire coil to shake,
much more than the wire coil could otherwise shake.
so the echo of sound off of the drywall triangles,
as well as the piezoelectric sound generated by the drywall triangles,
both contribute,
to the microphones electrical output !
5:
in addition to number 4,
the earths magnetic field,
is passing through the drywall triangles.
which means that the earths magnetic field,
is being converted into yet more sound,
by the piezoelectric drywall !
