this will get rid of arthritis.
Started by 11:11, July 29, 2010, 08:57:46 PM
11:11
most of the danger, is in amperage.
with small enough amperage,
even 2,100 volts,
will not be able to go deeper than the outermost layer of your skin.
let alone go into an organ.
high voltage is required,
to attract a more effective amount of negative ions.
if you have a few tens of volts,
than there won't be much effect.
a guy named fred bell sells a device that does the above.
but he uses tens of thousands of volts,
at a profoundly small amperage,
at very high frequency.
i tried his device, and it notably increased my mood.
as well as increased my stamina,
and sense of physical well being.
undisclosed research of mine indicates,
that if you attracted absolutely gargantuan amounts of negative ions,
that strange things will happen.
that the physics of the environment inside the negative ion cloud,
could behave in unexpected ways.
the_big_m_in_ok
Quote from: 11:11 on August 03, 2010, 03:47:41 AM
...i tried his device, and it notably increased my mood.
Take a look at:
http://www.pyradyne.com/star.htm
This looks straightforward in theory.  His unusually-shaped device may or may not be the telling difference?
...undisclosed research of mine indicates,
Can you be more specific?  What did you experience?
--Lee
11:11
Quote from: the_big_m_in_ok on August 03, 2010, 11:28:50 PM
Take a look at:
This looks straightforward in theory.  His unusually-shaped device may or may not be the telling difference?Can you be more specific?  What did you experience?
--Lee
i've caused a room to get moderately high in negative ions,
and a room to get extremely high in positive ions.
when i caused my room to get full of positive ions,
extremely nasty things happened.
things that i had every reason to think,
were going to kill me with their claws and their teeth.
if i say what the positive ionization CAUSED,
than most of the forum would chew on my ass.
as farrah-day-ism is contagious,
like a zombie plague.
my research associates negative ions,
with the higher densities.
the more negative ions crammed into a place,
the higher the density of that place.
there is an extreme amount of negative ions, inside each sun.
and on the peak of each mountain and hill.
john hutchison didn't just turn rocks into rocks.
he used high frequency sound,
to make steel melt into a puddle.
while the steel remained at room temperature.
i think the steel melting into a puddle,
was partly because the steel was raised into a higher density.
because the high frequency sound that hutchy pointed at the steel,
attracted extreme negative ionization.
ESPECIALLY in light of recent insights,
which suggest that sound attracts and conducts electrons and negative ions !
if you expose yourself to enough negative ions,
i think you would become invisible and in-audible to 3D humans.
and become able to seeing 4D and lower 5D beings.
such as pleiadians and reptilians.
amigo
11:11
Thanks for your posts, some interesting ideas and concepts.
Please carry on with posting more and ignore the detractors...
the_big_m_in_ok
Quote from: 11:11 on August 04, 2010, 02:21:53 PM
Well, okay.  I'll have to take your word for it.  No permanent damage to the body?  Things like a 1,000,000 Volt Tesla arc lightning bolt while you're fully grounded to earth?
A Cherokee shaman told me that's why shamans live on hilltops.  The energy is so positive.  Because I'm Native American myself, I can appreciate this point of view.
--Lee
