this is an idea that has been tried
Started by t00ls, July 31, 2010, 06:54:28 PM
t00ls
Many have tried this same idea , but not in the way that I propose.
  Traditional  siphoning action uses a liquid level higher than the place your siphoning to.
example: traditional siphoning attachment
however some have tried to do this: half baked siphoning attachment
what I propose to try is this:water generator attachment
simply put ...the intake is above the output, the large pipe will act as a piston in an engine...at its lowest point it will cause a vacuum and draw in water through the 2 inch pipe, filling it back up to the highest point possible
to start off, the large pipe and the pipe in between the 2 valves has to be completely full...no air. Once it is past the 2 inch intake , there should already be a zero or less pressure above the water
the reason for doing this is for people that have streams but dont have the head available...the large pipe along with the height should provide this
edit:I just realized the foot valve in the bottom picture is upside down
fritznien
look up ram pump. i don't think anyone ever used one for power but they pump water very well.
fritznien
