ideas how to collect the resonance power from high voltage
Started by ashtweth_nihilisti, April 18, 2006, 08:46:35 PM
ashtweth_nihilisti
series resonance is tricky ;)
if you just simply attach a resitive load it will bog down the prime mover, there are advanced ways of tuning it and creating standing waves and taping the 'nodes' of these from the alternator side, or what the inventor calls a tripple flux capacitor setting, but thats so far been too far advanced for this and a few other replicators to extract, or we are too lazy and stupid to tune it right  ;D so far this is the current circuit the group is working on as i right this
Quote:
here is a quick shot off simulation so you will see as the voltage
hits a level from resonance or anything, the FET auto switches on and
goes thankyou I will take that.
  I use this circuit concept all the time in my other circuit designs,
and didn't think mate, too just draw it out as a simple extraction
circuit on its own.
The component values will allow you too adjust clipping off the
resonant peaks from 80volts upto 300volts no problem with the
adjustable resistor on the circuit.
  If you want higher voltage collection you only need too change the
Zener diode value too a high voltage rating or just whack another
Zener in series with it.
  The only thing I didn't mark on the diagram was the FET model because
it all depends what voltage they want too play with, but the IGBT part
number I gave you before will be perfect. That's the 1200volt dude.
  Its just a perfect little circuit for tapping into the RV if you want
too, or on any DC motor collecting BEMF or whatever, and you can
adjust by turning the potentiometer how high or low of the peak
voltages you want.
But with the RV I have found you want the energy circulating in the
motor and left alone, but that's my belief so far and needs
confirming.
-end quote
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
