NaLi GeaRS by UTiLeeTY
Started by UTiLeeTY, August 15, 2010, 06:52:05 AM
UTiLeeTY
Quote from: Omnibus on August 16, 2010, 03:11:34 PM
You mention that unfortunate Whipmag. How do you envisage the stators to be changed for it to work? Sounds like a worthless pursuit.
Really, thank all your guyz first who ever made a whipmag replication and have shown your findings on videos or pictures.
You rock a lot and your replications are truly awesome!
@Omnibus:
If you've read my .PDF file, you could see 2 magnetic gates on 2 rotor wheels (there are just 2 magnetic rows per 1 wheel, too).
What I meant was to replace NOT stators
BUT you may replace just the 1 rotory wheel  (=WhipMag) with one of NaLi GeaRS type.
(You can keep all the stators like they are, ever more than better; please read rotor to stator rule in .PDF file, 2nd page I guess).
It's like if you would mix V-Gate (or SMOT) like device with a WhipMag prototype ;D.
Of course, stators may be adjusted while testing the device.
There must be not only 2 rotors, 1 wheel with 2 mag. rows with variable polarity (= part of NaLi GeaRS effect) will do it too.
Edit: Well, really complex is it not. All you may need to mill, were 3 parts of plastic rotors.
The middle part includes just piercing holes; not much precision at all and they may have some 'play', too.
Then both other parts, preferably from plastics, will need a bit more precision, because a shift between each bar round magnet 'profiles' should be like 0.2 - 0.5mm. I used 0.3mm (or 1/3mm) in my example  ;).
Otherwise, you may need bearings of your choice and ring/torus magnets from WhipMag project; smaller ones have preference, I guess.
Best Regards,
UTiLeeTY
Omnibus
Will be interesting to see what you mean by actually making it. Stators are the four small cylinders, right?
UTiLeeTY
Quote from: Omnibus on August 16, 2010, 03:57:47 PM
@Omnibus:
Well, I tought of something like 4+ stators PER gate rule;
so if you have usually 2 gates on 2 wheels (or 2 rows on 1 wheel), you may need at least 8+ stators  ;).
You can see it very clear in my .PDF file, page 8, last page I guess.
Greetings,
UTiLeeTY
BTW: time for bed, then see you all tomorrow  8).
Omnibus
Quote from: UTiLeeTY on August 16, 2010, 04:18:36 PM
@Omnibus:
Greetings,
UTiLeeTY
Yeah, I see it. So, I will wait for you to make it and show it how it works.
UTiLeeTY
Quote from: Omnibus on August 16, 2010, 05:42:03 PM
Thank you a lot, Omnibus  :D. We may just go for it too.
Please feel free to ask for help or questions.
Best Regards,
UTiLeeTY
After EDIT:
By the way, ... is anyone out there wanna 'sell' his non-working WhipMag replication?
Of importance were bearings, case and may be some ring/torus magnets for stators (at least 4 of them). Thank you for your offer.
