Going thru time vrs between it faster then speed of light
Started by cletushowell, August 16, 2010, 05:50:42 PM
cletushowell
Thanks seriously get this all in one day
dad comes into secret lab trips over wire
smashes my whole overunity
device then pissed he trips unpluges the cord to uncles
motorhome to charge forklift
my cousin interupts right in middle of my perfect oscilation
of unlimited ac over limit voltage
my uncle comes home and has no power gets mad thinks i unpluged
the cord and smashed my fucking perfect earth battery
all in one fucked day and this is the kicker with no power
there all fucked the motorhome would not work
the forklift would not charge and im working on
the circuit so these dictators can just decide
to shut us down.
Anyways thanks for the aether explination
now figure your not removing aether your overpowering
it with the black hole technology
and the particles of any object are not in your way the seperate
in exact stucture by expanding specific
gravity with enough power you go right thru
the particle does not know its expanded and contracted
the philidelphia exoerinent had two flaws one not enough power two
the water went through the ship
not ship through water esentialy
seperating the steel hull
i did this by expanding the light bulb while warping it
and pulled water in during the expansion
people got stuck in hull live
sm0ky2
you cant actually "remove" the eather, what you do is distort it, to the point that it no longer impedes your mass from traveling through it.
"effectively removing it".
Lets suppose there was no "einsteinian" barrier with mass vs acceleration, and energy approaching infinity.
how do we get there?
we remove the time constraint.
Here we do not see energy increasing infinitely.
We see energy doubling at the speed of light, and every subsequent integer of c.
But to do this, we must assume that the speed of light is only relative to ourselves, the observer.
otherwise, a universal time-constraint prevents relative travel faster than light.
If the speed of light is variable, it must be directly related to the "speed of time", which would also be variable.
"time" could then be defined as the rate at which things propegate through the aether (or space-time as science likes to call it.) and could be measured by the speed of light in a localized region of space. We could then develop a concrete definition of what "time" is, in relative terms. (Light-Years)
if the light year in another galaxy were 13,000 feet longer than ours,
they may have a time of T=1.06, relative to our time.
which means all of their physical processes would occur at a slower rate, the propegation of light, atomic interactions, the aging of life itself.
That's only relative to us,.
because to them, we have a time of T= 0.94
and everything here occurs faster than them.
But to each of us, our definition of "time", and the value of c would remain constant.
relative to the observer.
the question is,. even with such brute-force power, can your spaceship travel faster than light? or do the same forces that restrict a photon, and define the speed of light, restrict all things to a certain speed, based on their physical properties?
If you change the way you interact with the forces that cause this restriction, virtually moving space out of your own way, you can go as fast as your engines can take you.
cletushowell
95% shure i busted the free energy and wireles transmission
charging from the earth rod
its pretty simple
dc charger in wall
negative side to the car coil where the plug goes
that wireless transmits insidd the coil
beings theres no direct link
to the two prongs for the 12 volts and
points
that emits energy in ac and dc
and go from that to a nicad battery
from nicad battery back to the ground rod
you done it charges from earth now more testing needs to be done
but i swaped dc power supplys no different
its the ghz from coil not the power the ac
is oscilations the coil multiplies it to 2.1 ghz
and then emits dc and ac power
cletushowell
Your pretty smart but ive decoded everything
and I can tell you if you want to understand
anything throw out all the laws all the math
and go to begening of each design
by the time the bmw reaches 2012 youll
never reverse engineer it from scratch
now if you star with the steam engine
or lawnmower then you get the picture of how it works
so im telling you I have string theory
and its simple you dont go thru time
time goes thru with enough energy
you put it this way on aug 14 i caused a 7.2 earthquake
and solar flares on same day
so with that amount of energy
you can go to sun in one day
better yet energy goes thru you
its 144,000 so im telling you thats the
answer to anything you want
its also pie and 144,000/9/6/3
=8888888
which is infinity as well
sm0ky2
If you open that thing up, you see that the + and - form the primary coil.
the path from the (-) terminal to the plug-wire forms the secondary coil,
but it is all one continuous wire.
the two (-) ends are tied together inside of the thing.
"common ground", like everything in the car.
