a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
Edreak
HI David,
I guess my previous post about the silica geo magnetic effect was over looked but no worries.
With the PMH when you charged it up how long did the charges last for?
Have you tried stacking multiple PMH's on top of each other?
What is the max current you have used to charge the PMH?
A few questions to satisfy my curiousity... I've got some Iron Sand arriving today (I hope) so with any luck I may be able to put one together this weekend, now just have to find the Copper wire, oh btw what size copper wire did you use for the coil?
Thanks
Edreak
david lambright
edreak....how areyou doing?....i use a fairly heavy guage of insulated wire, like 20-24....on another forum, i read about magnetite sand from China...it is supposed to be very magnetic'......also manganese oxide is another one i would like to try....i will let you know about the mgnetite sand, cost, where to get it etc....david
david lambright
edreak....i am very interested in that type of photography!...i have tried the Slclieren method but the air is not being disturbed so no "good" images...my devices will stay charged forever unless the circle is broken [as far as i know] just like a PMH.....david...PS...i usually use a 9.6 volt DC NiCad battery [makita]...i have used a 12v automotive battery once....i need to try the 12v battery again, on the oxide core devices......i do not know if i can add more"flow" to an already charged PMH?....what do you think?......
david lambright
i believe Ed heated those segments past their Curie point before he assembled his wheel so that the iron was "fresh", with no permanent magnetism....scotty [loadstone?] shows that a PMH can be locked with a single long wire that goes through the center of the PMH, not even wraped around either leg!...you need to use a larger wire but it does work.....i can lock steel to ferrite with one wrap of wire... YouTube - david showing ferrite+steel PMH ...i have used a cap from a camera flash to lock a PMH also but i did not notice any difference in the strength of lock .....scotty said with a larger device, the strength of lock varied with input, voltage, amps etc. up to saturation....i think what i need to be looking for is material that can be super- saturated ....possibly an alloy or an oxide mixture...magnetite sand from china? ...the oxide core devices work very well, with plenty of visual radiations [vibrations?] and other super -magnetic [making all materials feel as being push/pulled magneticly] forces, radiating from these devices....replicators are seeing/feeling these SAME things...little by little we are figuring out EXACTLY how to reproduce this radiated wave, every time....for all replicators....this is something very different yet following some of the same sets of rules as electricity or magnetism...we all heard about the plastic film factory and the "wall" produced ...nothing there but an area made "solid" , by an invisible source?....this makes sense if these waves can add density or take the density out of a material ....in my first videos i am spinning a 14 pound quartz geode, with my fingers, it feels as though it has lost some of its mass and feels light. at this same time there is what looks visually like an interference pattern....i believe when these waves interfere or cancel,is when these effects are at their best....in affect, cancelling out some of an objects mass/inertia/gravity, it is all the same thing...the static wall shows us that something can cause invisible density or mass?...i propose that if a density can be manufactured, then so can its opposite, that can take the density/mass out...david
