a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
sm0ky2
@ EGoose
the "silting" effect has to do with the quality of the ferrofluid.
The more "colloidal" the fuild, i.e. smaller particle size, the better it will stay in suspension. There are fluids that can sit in a magnetic field for long periods of time, and not separate. High-quality fluids like that are expensive and difficult to find at times...
But you can manufacture your own, with a lot of effort.
the best ive done was to get an accrylic (or plastic) box, drill a hole in it to fit a piece of ferrous steel pipe
put a grinder bit on the dremmell, and go to town on it inside the box to catch all the steel dust.
when you're done, you should have a nice pile of dust, then run it through a very fine metal filter/strainer, to catch any large particles.
and CAREFULLY mix it, to avoid clumping.
the proportion of dust to oil is very important, and i never could get an accurate ratio formula. so you just have to play around with it, adding more dust until you get it to behave the way you want to under a magnetic field.
Liquids have a physical "droplet size", its hard to see this with oil, because its viscious.. but every liquid has this.
This is basically the smallest ammount you can easily break it down to, before the surface tension prevents you from breaking the droplet down any smaller.
when the particle size of the metal is close to, or smaller than the droplet size, the magnetic field cannot silt it out. It always remains coated with oil, the the oil will actually repel the particles away from each other. This is what makes colloidal suspension different from chunks of metal floating around in an oil..
david lambright
a concept
Uploaded with ImageShack.us
Uploaded with ImageShack.us this is just something i thought of, i dont think it will work.......the other experiment i did was too hard to keep the tube immersed in the fluid, very small flow only.........i think this concept should work....then again, i have been wrong MANY times before.....please let me know your thoughts on whether you think this will work or not...david
Hope
This is a concept using an aluminum tube Rodin coil shaped filled with ferro fluid then energized as a PMH which makes me also see it wrapped with TPU coils to capture the flow of electrons which of course will be a constant generator... though knowing of the magnetic field disassociation may be harder to capture.  Because of this "throwing of the magnetic field" there will be useful pressure causing a lot of activity in the TPU windings.  It shows promise in that by mere physical design of the Rodin coil the magnetic field is being perfectly circulated WITHOUT any "stick"(back emf) which of course is and has been the devil in these many efforts at magnetic OU.  Once again the natural path wins out at mere simplicity which would tend to show, though hard to make in build automation, is the necessary pattern of magnetic flow.  Working WITH this flow eliminates physical problems later in operation.  This is further confirmed since the design of the Rodin coil needs no insulator coating but yet does not short out.  Any comments are asked for and appreciated.
After drawing this concept out it showed that an outer covering tube instead of circular windings would capture flow unhampered.  So with this in mind the whole idea has a completed congruity and seems to be worthy of some bantering about of you all.  Still the coil could be or should be pulsed cycled within the ferro fluid building momentum and a harvest-able output should follow.  It is yet to be established if this will be a harmonic recombination which will yield amassed energies.  But this seems to me to be a natural assumption if the fields can not escape capture.
Hope
I have had a dream about this design and it has a glass Rodin coil filled with a fluid that resembles mercury inside.  There is a grid of diamond shaped gold colored wire mesh covering the glass which had what resembles quartz covering the wire mesh finely.    Within the shiny fluid are grid plates (just a few) here and there.  The whole coil is suspended within a golden quartz looking wire mesh that is saucer shaped which seemed to pulse with movement in the coil assembly.   When the outer mesh pulsed the inner grid plates glow a bit.  Hope this means something to a reader who can relate what this might be,  I am, like you all, searching for a way of generating power that is green and OU.   Thanks.
david lambright
http://www.youtube.com/watch?v=6ges-FQmYrk another video trying to show the flow of this energy and a brief explanation...thanks, david
