do you like this topic?
 no, it is BS
cletushowell
When god pissed off the dark
matter it was light in the begining the he seperates the
light which creates darkness then he says let there be light
he times his magic show till sun apears
around the earth then in end theres no
need of sun nor moon a light we are in a loop
you cannot die everyone lives eternaly whether its inside
earth when time stops or outside with time stoped and no watter now if you went to the moon and warp water then you would be a God
controlling the implosion and explosion
of planets so lets magnetise water and build a power supply
to send it to moon get off this dam planet
nievesoliveras
@all
This is my report of the device sent by @lambright.
I have not been able to make it work or to see the effect.
Thinking that maybe it was damaged during the mail journey, after several hours of having it hanged from a string I decided to clean it up a little.
It was a weather mistreated aluminum tube, so I sanded it and make it shine.
I thought that maybe giving it a 12v jolt will start it and did that.
Then shiny and with a jolt of 12v Hanged again on a string outside on the sun.
A neighbor came by to ask me for some community work and began to crack jokes about me playing with the device.
I ask him to watch carefully for the explained efect to see if he could see it and he could not.
Question:
What am I doing wrong?
Jesus
PS
I am still building an aluminum variable capacitor. It seems that the aluminum I could get is very difficult to cut and shape as desired.
If anyobody wants to replicate this Variable capacitor I posted the pdf here:
http://www.overunity.com/index.php?action=downloads;sa=view;down=437
cletushowell
Hey sparky did you send me a email
i just got a email no words you know I really want to
give this to you and rose but really you know who deserves it
is dave I would like dave to see what he actually
did if thats ok with everyone ive had this done for a few months
dave started this thread and he deserves the key
unless someone post it which i hope you dont
post it with the lines in the structure i give you
but you can spin that star of 12 to center in the
6 the edge of the circles should be between the point on outside ring
thats correct
sm0ky2
@ Jesus
it will not work unless there is a magnetic current flowing through the device.
You need to be sure this happens before attempting to make an observation. there are multiple effects going on here, when its "on", you will know.
If you are not familiar with this concept, i will make my best attempt to describe it and do so (hopefully) without befouling Ed's ideas....
essentially you have a loop of non-magnetized, ferromagnetic metal. (ceramics may be possible, ihavent tried)
at one end of this loop, you place a coil, or two coils,
i have seen it done with as many as 4.
Ed shows this using two coils on a "U"-shaped bar
with a "keeper" bar placed across the gap
Dave shows this with two coils on a barrell-ring type thing
You can see the effect when its "on" in both demonstrations, because in a) the keeper stays magnetically connected.  and in b) the bareel-ring, which is "springy" stays closed.
in BOTH examples,
when you break the magnetic current
you get an electrical pulse out the coils. this has been shown on meters, and to light LEDs.
You need to understand what the magnetic current is, and make sure that it is flowing through the ring.
Thats step 1.
and should/must preceed any experimentation.
Hope that helps..
sm0ky2
@ Cletus
i sent you an empty msg, so you would have my address.
i thought you were asking me for it
