0 Members and 32 Guests are viewing this topic.
do you like this topic?
 no, it is BS
nievesoliveras
@all
I was sad because the ring wasnt making the compass to vibrate when it was put beneath it while hanging on a string.
I unhanged the ring to restart it with a 12v jolt, thinking that was wrong and just before doing it I get the compass close to the ring once more but this time all around the ring.
The magnetic field was alive at the tape junction and this time instead of vibrating slowly till getting aligned with the magnetic field, it jumped to position with good force.
If you do not believe me just do the test on yours. It is alive!
Jesus
cletushowell
Man i must be getting bits and peicies
i think your talking about feeding the plant similar to this video i tryied to explain it not shure
maybee im just lost
Check out this video on YouTube:
http://www.youtube.com/watch?v=Xxicoj6iGvg&feature=youtube_gdata_player
cletushowell
After wwatching that video in reelized
where the helix is its right between those circles
i dont know how to convet the helix
but i do know were its at i do know how the energy flows get on your knees
like Gods makes us all and play in the mud like
me you see if you dig the trough put the
rocks in center the helix is the x
between the circles and water flows both directions at the same time
impossible you say yes so do i but it does
you can clearly watch the water and dirt particles float thru the whole loop and back to the begening
cletushowell
Sorry im on this i need help
take the water out the cup it floats antigravity
put the water in it sinks gravity
But thats wrong flip the cup remove the water
by energy floats the cup gas but you cannot
go back antigravity without
the hole in the cup im the top the weights and measures
of life the helix
ed explains he understands the weight and meausres
the small rock lifting the big door
the the small hole in the cup allows the energy to be put thru to inside the
cup but also allows the gas to flow out to go back antigravity
a helix why can i not transfer this type design to the rocks
its like so stupid its a hot air ballon
but tge heat is input from the top not the bottom
when the heat or energy goes thru the top
it lifts and drops fast the top is the
maximum energy always
the helix is
the --++
    ++++ why can i not see this
answer in the rock i think i need a time out
was his big wire aluminum or copper
or both
david lambright
jesus...if you shake your device, can you hear the oxide shaking inside the tube?....i might have not packed the oxide well enough....if that is the case, i can either send you some oxide or something....i need this to work correctly for you.....david
