do you like this topic?
 no, it is BS
cletushowell
The way i understand is tesla changed the
resistance of the air thru the tubes
adjusted the inductor to match
bouncing the caps which is the spring and turned the motor in
reverese unlimited energy by inputing a antenna
Im 99 % shure thats what he did based on sparks
explination and my reading of these notes on the bottom
of this video im trying to understand he bounced the spring with the always present radio waves the friction in the air
tuned those with the inductor
http://www.youtube.com/watch?v=aZNnwQ8HJHU&feature=youtube_gdata_player
sm0ky2
@ Cletus
Al + salt usually takes a long time. and most of the AL will oxidize before that happens.
Adding electricity forces the reaction to occur.
more electricity, the faster it happens.
its kind of like electrolysis, or the catalytic converter in a car.
And Sand = Silicone
   yes sand, like at the beach. they use it to make semiconductors. you can seperate it by colors, but its all pretty much silicone, with some impurities..
theres also Rosequarts, and magnetite(ironoxide),in there which you can seperate with a magnet.
The Magnetic Viewer:::::
ive tried all kinds of these, and this is the one i use, ive found it to be the most detailed, and most acurate viewer out there.
for some reason they dont show up very well on camera, but you can clearly see the magnetic field.
and theres many many more "lines of flux" than you get from other viewers...
so here you go..
get a Grinding wheel, just regular shop grinder.
clean it up, make sure theres no dust and whatnot.
and get a piece of hard steel. doesnt matter what kind some of mine are stainless.
place a plastic container underneath and grind it so the particles fall into the container.
(wear goggles and gloves, and use caution...)
collect a nice ammount of steel dust.
now, get two pieces of laminate
dont get the self adhesive kind,
get the kind thats made to be Heat-laminated
now, what you want to do is, take some lightweight oil
not olive oil because it degrades,
but any light cooking oil will work. also ive used "machine oil"
comes in little bottles with a spout.
shit expensive, but its great stuff
put oil on a cookie sheet,
the smaller you can find the better, i use a 1/2-sheet thats a little bigger than the sheet of laminate.
now, carefully mix in the steel dust with the oil.
i use a rubber spatula and just mix it around, then spread it back out.
you want a lot in there. not so much that it gets thick, but you want to not see very much of the bottom of the pan.
you can make 3-5 of these at a time, so you dont "waste" your oil-dust
but basically, you put a border of tape around the edges of 1 side of the laminate.
then dip it on the pan so the whole inside of the tape border gets coated with oil.
let it drip for a second, then flip it over and lay it flat.
now you need to move quickly at this point, so it doesnt spread too much.
Have your HOT iron (clothes iron) ready and next to you.
on a flat HARD surface. i use the kitchen counter...
quickly peel the tape off, position the top sheet
and iron the edges to seal it up before the oil spreads out to the sides.
now you have a perfect viewer, they last for years if you dont screw them up or lose them.
if it doesnt behave the way you like, you can add to or subtract the ammount of steel vs oil you put into it.
dllabarre
Quote from: sm0ky2 on September 07, 2010, 06:02:29 PM
Nice idea!
Thank you
cletushowell
Im lost on the aluminum silicon
im getting way confused
do you like have something against emailing me
ch@helpuflip.com
i guess i dont understand the problem
or if im just stupid you said the top chemist cant mix aluminum
and silicon then the aluminum is sand ok so why cant it be mixed
i dont understand im sorry i can mix it
this i know  im just so confused I dont understand the problem
or the importance of it maybee a email would clarify things for me.
cletushowell
Smoky im sory i got you mixed
up with hope but im still lost on the problem
im way frustrated to right now trying to
learn and write comments on the tesla black box
and my youtubes blocked again from all
electrical sites how they do that i dont know
it makes me very mad
