do you like this topic?
 no, it is BS
david lambright
as soon as i get access to a card reader, i will upload some stuff to my youtube channel...what i really want to capture is two oxide rings about 3" apart...a colored vortex starts to appear, but is more subtle than the radiation effect......david
Low-Q
Quote from: sm0ky2 on September 07, 2010, 10:37:46 AM
@ Low-Q
will this "litz wire" perform the conversion in reverse?
turning high-frquency magnetism, into Current?
if so,. then dave should perhaps use this in his tubes??
Yes, absolutely. I am talking about quite high frequencies. Any time you break a current circuit in a coil, it will appear very high frequency components the moment you switch it on or off. These high frequencies will convert into electromagnetic radiation if you do not take care of the skin effect. Using litz wire will prevent this from happening and instead conduct all the energy through the wire and to its destination.
Vidar
sm0ky2
Quote from: Low-Q on September 08, 2010, 06:46:40 AM
Vidar
I was thinking more along the lines of using the litz wire to pick up the magnetic radiation from around Dave's device, and convert it into electricity....
cletushowell
If you understand this may help
I found this today
http://www.youtube.com/watch?v=36n3ycOXWvM&feature=youtube_gdata_player
if the input power is put in first thru the same material
the frequency loss is contained in a ceramic like the car coil
i dont beleive your frequency would change with power
if you look at the seven circles understand
the seven is the 8 the center point
that puts 4 corners of the earth
fall winter spring and sumer into
12 months the next rings
if you split those into 4 seasons
you have 2 polarities winter summer
do not align spring and fall do not align
if you now have you 3 in 1
three loops in one circle ill get the cans again
I forgot the math on the callender i fixed ill
see if i can find it for the next rings
the days
cletushowell
Here youll apreciate this
I fixed the callender
So the day is actualy 12 hours
And God called the morning and the evening the morning were the second day gen 1:8
2x350 =700 /2 days equals 350 days a year
So 144,000/350
=  411.428571
Which equals 6 days + 6 = 12 months=
12+8+5+7=32days a month which leaves you with 1year and thus you find all the numbers in the Bible are now unlocked
Ocording to this the next ring is 32
ill try to figure out why
