do you like this topic?
 no, it is BS
gravityblock
How to make instant hot ice, http://www.wikihow.com/Make-Hot-Ice
Make an ice cube sink with heavy water, http://www.wikihow.com/Make-an-Ice-Cube-That-Sinks
Use a vacuum to freeze water in less than 90 seconds, http://www.youtube.com/watch?v=pOYgdQp4euc&feature=related
Dry ice, http://en.wikipedia.org/wiki/Dry_ice
Let's not limit ourselves to just freezing the water and melting the ice in the conventional way.
GB
david lambright
hi everyone....@jesus...@jetijs...try viewing in a very dimly lit room.....let me know how this works!...david
MasterPlaster
Quote from: cletushowell on September 08, 2010, 12:18:00 PM
Here youll apreciate this
I fixed the callender
So the day is actualy 12 hours
And God called the morning and the evening the morning were the second day gen 1:8
2x350 =700 /2 days equals 350 days a year
So 144,000/350
=  411.428571
Which equals 6 days + 6 = 12 months=
12+8+5+7=32days a month which leaves you with 1year and thus you find all the numbers in the Bible are now unlocked
Ocording to this the next ring is 32
ill try to figure out why
@Cletus,
You are wrong my friend.
I have attached links to some old writings that may interest you as they contain a lot of numbers:
http://www.youtube.com/watch?v=UukVS-tcqa8&feature=related
http://www.youtube.com/watch?v=3uk5OD-uwbo&feature=related
cletushowell
I solve the over unnity circuit
in math 7 makes 16
16 is two 88
8 makes 7 and 1
7 makes 16 16 is two 88
7and1 16 88. 7 7 11
7and1 16 88  7 7 11
7 16 88 77 11
7=16 88 77 11
7=16 88 77 11
7=16 88 77 11
but the 1s multiply 7 always breaks down
to 1and6 which is two 8 sweet sixteen
the path is straight and narrow
the 1 so hope you see marcos 369
9 always becomes a 3 and 6 no over unity
ya free powers just around the corner
i smell the stone soup a cooking good
cletushowell
I dont know how and what point these messages should go private
i feel many of these questions hold answer to your prodjects
some of your are in really far science and
some are not the callenser i did is the way i understand i relevant to the very structure of everything the time at which the planet
moves the time on earth and callender change as time becones no more the
time is the center as tine here on earth becones no more
the time elsewhere extends the reading of the book of enoch
in the video are included in my geometry i did for you
the six stars make the seven the seven holds
earth in the middle these are where the angels were cast
the great split is the grandcanyon
I have not done the 7 mountains in rev
soI cannot tell you were those are you can discharge a black hole
with water and only water the larger it gets the more water
the geometry i did when i finsh the stars like my brother asked shoukd put all the gaps around them for you the Gaps tesla put in the motor
the gaps edd put between the generator wheel
if you look at the message above the magnets have to be in offesting harmony what does a air coil do offesfs harmony
what if you built the air coil in seven it would have eight gaps
those wound in the 3 6 9.1 8 8 but did them reverese spirals in series
then wound another with iron around the zink
then your getting close to the sweet 16 you would actualy need 4
like lazer sabers wheel i beleive has four magnets
if you had four coild you would have two polarities
instid of 2 polarities turning four magnets
laser saber joined the two 2 1 one each side
thats the two halfs of the body theres four half two end wires two people  the basicaly having intercourse over his wheel I dont know where to put all this its
off topic of radiant but the coils radaite
how they radiate is the answer when enoch is replied there cast there
based upon there sins thats the polarity of each star
the amount of frequency of each mountain the points of the star
bind the center the amount is not determined why because it can be one soda can in the middle or a bunch spread out
