do you like this topic?
 no, it is BS
truthbeknown
cletushowell
The circle is perfect so when the numbers
align its magnetism the electrons and protons
=neclues so any pipe is a circle of energy
the gap = the numbers out the circle those
seperate frequency of numbers that cannot
circle in the ennegram he seperates the 9
but you can seperate any number or series of numbers
i did 3 videos 30 min Ill upload when I can
cletushowell
here is a drawing of the magnetism the cut in the pipe is where the line goes thru two numbers you might not understand why they go thru some but they do perfectly for example why does a 10 go thru a 65 well 65=11 11/2=5.5
5.5 =10 so 10 10.
7-23 23=5 2.5 2.5 25=7
8 thu 34 =7 3.5 and 3.5 =8 8
I think the rest are easy enough write if you have questions
I dont know if this is what einstien refered to as unified field but its perfect every direction there is no holes in I I call it Faith based mathmatics
because you can beleive there is any number and create the others from it
you can essentialy see where the light goes from the bulb and back to the light I dont really know all It can do its not in the string theory patter but I think Its because as life moves numbers change but they always stay in this pattern  it pretty complex the center ring is on the outside of daves device lining up the numbers like 333 then that would split taking energy aligning the energy in the next material
cletushowell
I have the flower done
i will try to draw it in paint
but the cut takes the energy fills it to the
center where the missing number would go
as soon as its unstable the nucleus cast it back out
so like puting a object over the cut the energy is sucked to the middle
then you need to remove that object
discharge the center and then refill it
the cut can be moved anywhere to any
of the frequency due to the doubled power on
outer ring you and they all lock on teslas 369
well maybee could go any of them i did 369
it was easiest
void109
I have to concur.  It does appear this thread is in the process of becoming or has already become severely derailed.
To add to the original purpose of the thread, I did want to report I have not yet seen any of the observed effects.  But I'll be the first to point out I havent created an identical replica yet, just PMH holders of the U + keeper format, as well as some experiments using ferrites and ferro-fluid setups.  These were done on the assumption that I COULD replicate the effect if I followed the original, so I thought I'd try something new to contribute something new, but given my lack of success I'm going to do an original replica next (galvanized steel pieces).
Thanks David :)
