do you like this topic?
 no, it is BS
cletushowell
I had to go chop the magnet in half to prove i was right
if you take a donut magnet and chop it in half it repels
itself because 9 and 9 can no longer go back together
it has to flop but if you cut only one side like daves
the magnet is trying to push itslef apart but cant
because its not split clear in half creating the glimmer
cletushowell
When you gap the broken magnet it
creates a vibration effect
so when you break the magnet
the numbers line up perfect on other side
5,10,6,11 top left
5,10,6,11 bottom right
the exact polarity for magnetism
Really I stole it from a alien
I think you need some conspiracy
stuff for your books
Bottom left
4,8,12,7
4,8,12,7 top right
amazing how perfect it is I couldnt
do it again I dont think if I tried
cletushowell
The reason it creats vibration is the center
magnet trying to find 9 between the gap its harmonicaly
of and bounces back and forth till 9
if you could get the magnet swinging
the more it swings the easier it is to cross
9 but if you can get it right between 5 and 4
never let it swing and never let it stick
your power would be incredible because your crossing
9 at such a rate like the magnet on the flywheel
spins past the coil but if you timed the circle of energy thru the
magnet it would always be out of phase
and never Grab 9 it would take spining the outer magnets
to see when nine lines up again to know exactly when to input just a bit of the energy from the first passes to push it past the locking
point your spining the ball around the pole the closer it gets the more power
right when it should hit the pole you move it the ball goes thru the pole
the field pushes it again how can you do this you ask
make a 54 next to it so the center is no longer 9
at the exact time the ball would hit nine
theres no nine you need to measure the glimmer
find the elctromagnets to put on inside
to make glimmer go away when you can do that the
at the exact time you would hit 9
activate the electromagnet for millisecond
theres a easier way
take the energy from the 5 to the 1
the 1 is the weakest power
it will add 514 =10 9 canot get stuck then
remove the bridge between 5and1
5 and1=6 you have to force it out of the 369
anytime it wants to stop by gaping the number
to one side to 1
cletushowell
Tesla hit the ball with radio waves
same principle take the 5 to the end of your
magnets or you can even use some of daves discoveries
how the different rocks emit the energy
match the coil to the zero point rock thats fluctuating
polarity it will never get stuck because its
taking in frequency every frequency is different
like putting a stubblefield coil thru the gap
it will never get stuck it will always move
it cant find a center there is no center
its changed with frequency from air
cletushowell
i know you hate me but I see a stubblfield coil
goimg thru the gap on a pendelum like
newton teslas ball on a string
newtons slide and the coils abikity to produce its own opposing field while generating energy thru the magnet
