do you like this topic?
 no, it is BS
david lambright
loner...as far as i can tell, you have done every thing "correct"...as far as that goes...i can get a mechanical lock with fewer segments but with 24 segments, it is only necessary to start the flow of "magnetic current" with a small coil....smokey2 suggested using larger copper wire to get a good flow started...i will take my #1 device apart and start from the begining to see if there is anything that i might have missed or maybe there is something helpful i am overlooking...i really want you to get this....@smokey if you read this , maybe you could offer some helpful advice?....one thing to remember though, this energy/radiation is visually very subtle...but it is there!....i will try and answer any questions you have....david
david lambright
loner...i took my device apart, re-sanded the segments and re-assembled the device....i re- energized the device using the same 9.6v DC battery, remember to switch polarity and just a quick spark is all it takes...a quartz crystal held around the device and turned slowly should give results....also a metal ring, steel, copper or aluminum, about 12" dia. gives a good view of this radiation/energy/field....here is a bit of a post by Lizzie at thunderbolts.info...ilhelm Reich called it “orgone” energy and even developed some methods for manipulating it. It is probably related to the spin field that Russian scientists have been exploring in the last few years.Here is an excerpt from an article from a couple of these scientists “Yu.V.Nachalov and A.N.Sokolov” which links a variety of related discoveries to spin fields:
“In this article the experimental results obtained by various researchers in the period 1950-1990 are discussed. Since all experimental results under consideration could not be explained in the framework of existing theories, these results were placed under the category of "experimentally-observed phenomena."It is shown that all of the experiments considered here have demonstrated a manifestation of spin-torsion interactions.
Over the course of the XX century, various investigations in different countries, representing a variety of professional interests, repeatedly reported the discovery of unusual phenomena that could not be explained in the framework of existing theories. Since these authors could not understand the physics of the observed phenomena, they were forced to give their own names to the fields, emanations and energies responsible for the creation of these phenomena.
For instance, N.A.Kozyrev's "time emanation" [1-4], W.Reich's "O-emanation" or "orgone" [5], M.R.Blondlot's "N-emanation" [6], I.M.Shakhparonov's "Mon-emanation", A.G.Gurvich's "mitogenetic emanation" [7], A.L.Chizhevsky's "Z-emanation", A.I.Veinik's "chronal field" [8,9], "M-field" [10], A.A.Deev's "D-field", Yu.V.Tszyan Kanchzhen's "biofield", H.Moriyama's "X-agent" [11], V.V.Lensky's "multipolar energy" [12], "radiesthesietic emanation" [13], "shape power", "empty waves" [19], "pseudomagnetism" [20], H.A.Nieper's "gravity field energy" [21], T.T.Brown's "electrogravitation" [22], "fifth force" [23], "antigravitation" [24], "free energy". This list can be easily continued.”.....anyway....more soon...david
david lambright
loner...i too think a battery works better than a power supply...a friend of mine has a camera flash setup that has been modified to use as a "sparking" device with the capacitor..we used it successfully to charge a standard PMH...so a cap works.....also i took a charged PMH, and an uncharged PMH, hooked the coil wires together and pulled the keeper off the charged PMH and it locked the other one.....quartz crystal interacts well with this energy feild.....metals also work...spin your device and hold mineral/metal object at plane and turn it slowly over and around...you should feel a difference, like slight magnetism.....let me know ......thanks.....david
david lambright
his is an email i got a while back;........2 attachments (total 3.8 MB)
DownloadDownload
View slide show (2)|Download all
Check out the attached pictures and feel free to share them with anyone you want to
Im not going to post them because some blog basher would start asking me questions about something i know very little about      ( I feel for you dave ) Don,t let them bring you down
Now that this device has been charged for a few weeks the waves seem more visible
Its kinda like if I try to look to close I cant see it as much.  I think the brain tricks itself because it knows its not normal, kind of like when you look at spinning spiral video and everything is wavy after but in reverse
Im still looking for something good to mount it on and give it a spin
Anyway Ill let you know if I find anything interesting
                  Tom
this was back on 7/14/10.......i do not know how to post the pix but i could email them......david
