0 Members and 23 Guests are viewing this topic.
do you like this topic?
 no, it is BS
zapnic
hi dave
couple on your videos there is pulling effect
i like see more that  effect
bye
nievesoliveras
@lambright
Just forget the problem that the people cannot see the effect your device has.
Direct your efforts to get any energy from it if it its possible.
Also divert your attention to other things and the right idea will come to you.
Jesus
IotaYodi
QuoteBut I think what you've disclosed is that there's a definite interaction with light and what may be an electric field or a magnetic field or both.
This is the part that astounds me with his hand held laser pointer. Its the most important part in my opinion. What frequency of light is better? Is there more than one frequency like white light? Frequency of the light pulses? What distance from the coil? Whats the laser pointers electrical characteristics? These photons must be doing something.
What I know I know!
Its what I don't know that's a problem!
david lambright
this is  post by van t stride on aother forum..                                        Hi-
So far, I have been a lurker in this thread, but also an avid reader of the forum and following David's YouTube vids. I KNOW that he is correct in describing what he feels / felt, while experimenting with his device.
Here is my experience: I don't have resources (time, mostly) to build David's rig. So I built a small 3" PMH which consists of two semi-circular pieces of spring steel, filed on the ends, to make a slightly oval profile. I used about 25 wraps of copper wire and energized with a car battery. Both halves are magnetized together (locked). The overall shape looks a bit like an egg. (There are no heels or legs sticking out.)
I mounted this to a circular piece of plastic with zip ties, used a carriage bolt with a hex-nut - on the underside of the disk - and place the bolt in my variable speed drill and spun it at approx. 500 RPM.
Using a variety of stones that I have collected over the years I tried every one (including Amethyst geodes which contain quartz) and felt very little - if anything.
Then I tried a green rock I have which is very heavy for it's size which definitely has a great deal of crystalline composition (might be a form of Serpentine). Using this rock I DID feel a PUSH in my hand which varied depending on how I moved the rock in relationship to the spinning PMH. Looking closely at this stone, it does have at least one surface which could be viewed as a "cavity" (CAVITATION?) that is a finger-nail sized depression in the surface. It was near this surface at about 10 degree angle to the spin plane, that provided the most feedback (although I sometimes did feel a similar push using a pointed end of the stone nearly touching the "axle."
Comment to Dave: Hang in there, buddy, I know you are right - check your geode for cavities / surface features that could be somehow collecting and amplifying the effect.
I also noticed that Dave's rig is without one feature that Ed's rig included (and I have seen it in other's pictures on the forum) which is the "Quatrefoil" shape (PMH?) on the top edge of Ed's machine. I would theorize that adding a part shaped like this on Dave's device may amplify or "tune" the output??
I am also in Oregon, I live well North of Dave, but both my wife and I have felt a clear "push" when moving this stone over the PMH. I am tempted to take it to his "neck of the woods" and try it there. I also saw (with my eyes) some "interaction" between the stone and the PMH but I doubt it could be filmed and I am trying to decide if I really saw what I believe I saw.
Also, I feel a little odd when I am around the PMH for extended periods of time. I slept with it on the night-stand last night and slept very well, but woke feeling very off - something  in the pit of my stomach???
-Van
this was yesterday....david
david lambright
Edit postDelete postReport this postReply with quote Re: Ed Leedskalnin
by david lambright » Sun Oct 17, 2010 9:03 pm
Edward Leedskalnin built coral castle and he used the same energy that i have re-discovered using my devices...there are more and more people replicating these devices...and getting the SAME results as me....the "gravational" or magnetic push in materials that do NOT exibit normal magnetic properties....the visualdistortion around the devices and the vortice formation above the device....i know that this theory is correct and now that there are other WORKING models, making the same energy flow...Ed never told anyone how...but he did leave clues....i saw a blurriness in his b&w pix and realised it was this same energy flow that i was seeing around his PMH.....this IS the energy he harnessed....as time goes on, more and more people will build these types of devices and will find out ALL of this energys properties....thank you all for your interest and replicating the devices....i will continue to try and help anyone who have not got results...hopefully these new replications will radiate more of the visible spectrum on this subject!.....thanks...daviddavid lambright
Private messageE-mail david lambright
