Please BAN and remove all posts from user cletushowell
Started by FatChance!!!, August 17, 2010, 07:50:53 AM
sm0ky2
@ FatChance
i will have to 2nd the Observer in saying that this thread shouldn't even "BE"
much less should be be considering its intent "ruined" by the very person it was meant to attack.... this is a community.
we will not get anywhere by acting aggressively towards one another. better that we try to understand someones point of view, and if necessary give them the opportunity to educate themselves, and develop their point of view into their next level of understanding.
some peoples minds are very delicate and need to be gently guided, to steer them back on course.
the fact that you percieve someone as crazy, predictates that their mind does not operate the same as yours.
Thus by telling them that they are crazy and their ideas are "wrong", you are not likely to arrive at your desired outcome.
Not to mention, that his own mind is not likely operating the same as his. probably onset by inconsistent doses of ritilin and zoloft.
(or whatever medication his doctor prescribes that hes not taking as regularly as he should.)
im sure in some obsure way, everything hes saying makes sense to him. My only frustratoin with him is that he can't seem to express these ideas in a way that makes sense to US!
i only get what hes saying about 1/4th of the time.
and most of it seems to have come from an experience he had some short time ago, involving YouTube and Marco Rodin.
give him some time (like his remaining 3 yrs in highschool), and things will start to "click" inside his head.
cletushowell
If you want me to answer things you know
then here I tell you the sun rises every day
if you want me to tell you the unknown
the sun is a hologram of energy
from two other power sorces its the light bulb
Marco refers to this as dumbing himself down
to speak to the average who refuses to
let go oc the fact every one failed
math because the math was wrong
everyone failed color because the color was wrong
everyone failed music because they dont understand
144,000 is between the key e and f
electromagnetic frequency
e and f
when you make the string tune e on oneside
f on the other you sac slide your finger
to any note
so everything is wrong what do you want
me to lie to you and tell you its right
maybee you get one day oil is charged
from the same frequency just like hydrogen
its just a liquid and still does not blow up
till a vapor so of hydrogen and oil have to be frequency vapor
then why are we using liquids when we can just add less frequency to the vapor direct
cletushowell
Then when you finaly see oil and hydrogen
are frequency you get to bendini
and lid and tesla turbines direct which is what I gave you
till then we need a bridge that bridge invokves dr stiffler
and me and lid trying to go backwards from
frequency to make your hydrogen
for your cars and power for your house in 120 volts
lod building motors along with bendini
dr Stifflers building hydrogen and im trying to bust the frequency backwards for your house power
so everyone has a bridge to cross
to the end frequency power of everything
sm0ky2
Quote from: cletushowell on August 26, 2010, 10:55:53 AM
i set mr nichucu or what ever that top physiscist on tv
straight when asked to do this formula
and explain this plasma which i did in ten
minutes
Check out this video on YouTube:
http://www.youtube.com/watch?v=FrJ1uVRLWfo&feature=youtube_gdata_player
This is simple 10th grade Chemistry Class.
The hot flask heats the air inside it (notice he turns it upside down after he empties it to keep the hot air inside)
when he places the glass into the cool liquid, the cooling air in the 'neck' condenses and the suction draws the liquid upwards.
he then pours cold water over the hot bottom of the flask, accelerating the cooling process, and further condensing the air inside. This creates a low-pressure area (static head) in the flask.
the weight of the water and the suction of the low-pressure hold the water in there.
when he tilts it to the side, a vortex of air is sucked down from the surface, and up into the flask. Some of the fluid is released when he does this.
The college level description of this includes the volume, temperature, and pressure of the air inside the flask.
And describes the energy transformation from changes in Heat/Volume/Pressure, to the (mgh) equivalent of the mass of water rising a certain height. And subsequently, the mass of water that is displaced by the ammount of (room temperature) air allowed to enter into the vessell, and pressure changes as a result of doing so.
and yes, im well aware of your conceptual knowledge of non-specific matrices, and the fact that you can reduce this to esoteric number values to simplify the math.
But it would help you, from the standpoint of "understanding" the problem, to at least learn the conceptual basis of the science before declaring that it is "wrong".
cletushowell
@smoky2
Glad to see you ran into the brick wall
you missed the plasma you missed the color change
you missed the water does not have to be water but a wire
you missed the torch is blue to start with
the fluid is red and blue blood of the lamb
indigo you missed it changing the plasma
as it goes up the neck from red to blue
you missed that the energy was trapped and
and the glass was already cool which from
you temperature should have reverse the fluid
back and you missed the fact of him safely drounding the glass through the
cloth oh waith is that cotton no not ben franklins
cotton and glass then you odviously missed the lightning
the end result of the plasma next
