Ed Gray's Magic Tube
Started by Zarko, August 24, 2010, 09:08:17 PM
ramset
Turbo
"A better world"
Our only motivation, and the best one !!
This quote slapped me in the face from your post # 13 on this thread
Turbo
I found that when you hit the already charged metal with a high voltage source, two things happen.
1. you get a natural response that can be loaded, and which settles things down again so that the charge on the metal will again be equal to the charge of the local evinronment, and 2. if you do this fast enough, and at a frequency or a division or harmonic component that is related to the resonant frequency of the metal/wire, or wavelength of the wire that is being charged up, or for example extracted by a tuned tank circuit nearby, and he who sits in darkness shall see a bright light""
end quote
Are we taliking NMR - NAR Here whilst the environment responds in a most productive way?
I certainly hope so..........
Thx
Chet
Thanks Grandma
Grumage
Quote from: Turbo on January 15, 2014, 09:40:21 AM
Thanks guy's  :)
Hope to make this a better world.
Dear Turbo.
With regard to the video.......http://www.youtube.com/watch?v=TNDJcyLBf0c
Does the pancake coil have any bearing on your experiment ??
Cheers Grum.
Addendum. Sorry turbo !! I have just watched an earlier video and realised that the Pancake coil is your receiver !!  :-[
Turbo
Quote from: ramset on January 15, 2014, 09:52:52 AM
Turbo
"A better world"
Turbo
end quote
Thx
Chet
Chet,
Not directly, this is about using the available voltage from the earth's electric field, to create current, by forcing the natural re-balancing flux to flow through the load , or to convert energy from the earth's electric field into radiowaves in the electromagnetic field of the earth.
I hope you noticed the simplicity of the very first experiment i presented.
Don't make things too complicated, the simplest solution is the best solution, most of the times.
All i can say is that if you want to know more you have to do these experiments yourself, simply because, to he who has, more shall be given.
ramset
Turbo
That sounded so nice I had to write it Twice [or again]
@Turbo  Quote
""Not directly, this is about using the available voltage from the earth's electric field, to create current, by forcing the natural re-balancing flux to flow through the load
end quote""
And yes I do understand the work ethic and also appreciate that part.
thanks for lighting this thread up as well as our interest!
Chet K
Thanks Grandma
tim123
Quote from: Turbo on January 15, 2014, 01:34:18 AM
You can click my website button for an example of the mechanism i was describing.
(http://www.youtube.com/watch?v=TNDJcyLBf0c)
Hi Turbo,
  the video you link to- can you explain what's going on there please?
I.e. what's the setup - presumably the coil in the background is related?
Thanks
EDIT:
I found this vid of yours which explains:
http://www.youtube.com/watch?v=_ze8cVIqSkQ
