Thanks to ALL for your help!!
Looking at the Rodin Starship Coil
Started by CLaNZeR, August 30, 2010, 12:12:31 PM
e2matrix
Quote from: Jimboot on September 01, 2010, 06:56:35 AM
Wow i am reading this http://markorodin.com . Makes a he'll of a lot of sense to me.
WOW is right - quite the staggering implications across all realms if it all goes forward as it seems he is envisioning.  I always believed in the power of the torus and especially the Rodin style.
Nice work on Clanzer's setup too.  Does the Rodin starship coil create a toroidal field also?
Cloxxki
Could anyone hypothesize how a similarly wound coil would perform when:
- 9 pins are used
- 1-2-4-8-7-5 winding&stacking pattern for first wire
- interlaced with a second wire 3-6-9
- also a coil wrapping the stack of, say 30 winds as above, going up the 3 axis, down the 6, up the 9, down the 3, etc.
- then a simple coil wrapping the 0 axis.
Too random?
CLaNZeR
Few more videos
CLaNZeR adding Magnetic Bearings to the Rodin Starship Coil Config
Thought I would have a go at trying the magnetic bearings. Again a quick bodge, but next step it to get it mounted in a solid fashion and see what sort of high speeds we can hit
http://www.youtube.com/watch?v=Y-3RtEPfYgg
CLaNZeR trying Magnetic Spheres with the Rodin Starship Coil
The Magnetic Spheres turned up. So testing them out.
http://www.youtube.com/watch?v=f3tBt38VTkc
CLaNZeR Rodin Starship 85mm Coil and Axle Rotor Part 1
Looking to see if a an Axle motor using the Rodin starship coil produces much BEMF. 85mm Coil made for this one
http://www.youtube.com/watch?v=izBpoT3PPxI
CLaNZeR Rodin Starship 85mm Coil and Axle Rotor Part 2
Doing the LED test and pickup Coil on new Axle config
http://www.youtube.com/watch?v=OAa8nWm5AOI
CLaNZeR Dual Switching the Rodin Starship Coil
No Reed switches, No Hall sensors, just pulsing both windings opposite ways. Using a Pic Chip to pulse and two SSR relays to switch each winding
http://www.youtube.com/watch?v=rYtlWaI07WU
http://www.overunity.org.uk
CLaNZeR
Quote from: Jimboot on September 02, 2010, 07:08:41 PM
I'll be winding a torus tonight. Going to hook it up to my ossie motor
How did it go Jimbot?
Cheers
Sean.
Paul-R
Quote from: CLaNZeR on August 30, 2010, 12:12:31 PM
Thought I would make a Rodin Starship Coil and have a play.
Please forgive my ignorance, but what does a Rodin, or indeed the Rodin Starship
coil actually do?
