Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
cletushowell
Because its electrolizing does not
make it a bettery its a feather and a battery
why did tesla feed the pigions he knew the frequency
of the energy the look for to fly
why to the birds sit on the electdic wire
theres static why do the bids land when my earth battery was perfect
it emits a energy frequency like before the storm
the static that causes lightning this coil is like a feather always
harnessing the static from the air
the crystal salt helps it receive
crystal is a radio receiver the crystals form in the frequency
the coil is built depending on contaminents
how those crystals for determines how well it produces
try doing like a bird wrap the salt with
more feather see if indeed it does
pick up static theres white noise
on every one of my radio chanels
thats not tunned i dream of that power
running my car
cletushowell
The magnetic amplifyer is the radio
take the radio like lid receive the frequency of the coil
but instid of playing the speaker play the coil
make the coil the speaker make the
motor the cone make the pulse of speaker
turn the motor feedback is over unity
if the motor is the speaker then the mic
or anttena picks it up feedback thru the magnetic amplifyer
very low power i would build it i dont know how
cletushowell
I said all this backwards or ill say it twice because its very important
the casset tape is a recorded magnetic feild
the radio magnifies that feild to the
speaker but the speaker is a coil
the pulse moves the speaker but
the magnet is not in the cone its in the
coil reverse this system make the coil spin
on the string like newtons pyndelum
effect but way improved we have done experiment on radiant
enery that really prove the best design
is reverse of a regular motor the power from inside
by spining a magnet on a string
lids spining the magnets on a string as well
but im saying this is a good design woulb be better design
it the coil was in the middle like helicopter
energy up thrust down lazer saber
you and lid can finish this just imagin your wheel stationary
and your coils spining then the wheel being your receiving
being the receiving anttena back to the coil
and what ever circuit magnifies the power in amplifyer
magnifyes the power now work back wards
was there ever feed back in a non battery radio
how and thats what we have to duplicate
requires going clear back to the begening.
Sorry if im conffusing im limited in mr radio side
only understand speakers pa ohm loads
some of the amplifyers stuff my guess is the tube
has the answer something about tube amps make them
very expensive they do something no other amp does
and do you know how when you drop the ohm load the speaker power goes up ok when I built my car coils to wireless power the razor
and stobe sorry i dont know how to light led or flourescents
i did figure a way to tune the cap to make it sing
different buzz any ways when i put three car coils
essentialy next to each other with the same
120 going into the spark plug side
when i drop the ohm load by
crossing the +- side like in series and parrale
my power goes up to my razor
so in order to magnify the wireless
power you need several receivers
those arnt droping power load there droping the
ohm but unless there wired together it apears mutiple receivers
dont increase the power but in serries and parralel
they do turning the power down on the metter but up to the razor
and really maxing the amp mutiplication
from .001 amps i can get 2.35 out
and if i knew how to drop the ohm load more
im shure it could way over power that razor
i think thats what i did some how when i spun the drill
powered the radio and the razor it was unlimited
but what droped my ohm oh maybey when i hooked up the radio it was working in reverse from the power supply to my coils
but why did it stop i dont know much about radio
but im rethinking my set up i hooked the car coils up
to the radio i had the razor spining the radio drew a little juice but came on
and was playing fine i then thought
well if i can power a radio and razor i can power the drill
so i got a big drill 6 amp and spun the shit out of it
till i realized it had a second speed at which point everything stoped
my guess is now that the inside of that radio amplifer was droping and storing my energy into what was those heat sinks i think those are what i use to burn out when i fry my amp by to much
ohm load on the speakers so this electronics guy would solder me in more
but what do those do how could the be working in
reverse to drop the ohm load on my coils to power that big ass drill
im trying to to you lazersaber and lid because i dont understand not one part from the wall plug to the radio but from the radio out was 4 small speakers wired in parralle so basicaly the speakers matched my coil input
oh it pretty confusing if only I had some one to work with who understood all this maybee no one does im kinda making myself look stupid even though i know it powered that drill and must burned out something in the radio
ill take the radio apart find the burned out peice
then well have the answer if its a odvious melt to me
if not were fcked.
flathunter
Quote from: Omnibus on September 04, 2010, 02:56:01 AM
There's a major problem here. What is this stubble field coil, if I got the name of it correctly? If that's just two dissimilar metals separated by an electrolyte-soaked cotton to form a Galvanic cell (not a capacitor, as the narrator puts it) then it's as trivial as can be and the whole thing is to be dismissed out of hand. If there's no contact via an electrolyte between these two dissimilar metals in whatever that coil is named and there's only an air gap between them then it's pretty interesting. If that's the case the first thing to do is put the device in a Faraday cage while having the two metals carefully insulated to avoid any Galvanic potentials. Thus, more is needed to demonstrate that this is a self-sustaining device.
Why not watch some of lasersabers (or lidmotors) videos, so you can see for yourself exactly what they are doing?  You could even try replicating them...its not like you dont have the links.
Your comments on here would then be more relevant as to whether this is OU or not.
I agree with Rosemary - Lasersabers NS replication is one of the best things I've seen on here.
Omnibus
Quote from: flathunter on September 04, 2010, 11:16:41 AM
Like I said, this should be discarded out of hand. A motor powered by a galvanic cell is trivial. Some basic competence is needed before getting into OU research and making big claims otherwise you fall easy prey to the zealous activists.
