Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
cletushowell
Lets make this very clear
anyone who discredits lid, lazersaber,benidini
stubblefield,jouel theif is very simply Goverment and or
haliburtion oil these are the answer one or more in
combination can free power virtualy anything
and the joe cell need really to be done
again or find this guy and why we dont have these joe cells
running our cars they work I have not built a complete one but im testing
trying to understand each step and right now im on the antigravity
and it works so these are all your answers
these are the smartest guys who can take us off oil
and natural gas and solar and the stuff dave lambert is doing
is setting the bar and helping us to understand the principles
of the very energy itself.
powercat
Hi Rosie  ;)
QuoteI don't know that anyone can definitively state what's happening, but - for what it's worth - my own take is that we've got induced magnetic fields collapsing and interacting with the spinning magnet in synch. I agree it's important to discover whether it's the combination of copper and iron - or wether one can use either one.  And I'ts reasonably important to discount any electrolytic process - but I would have thought that's pretty well discounted precisely because the surfaces are dry.  If moisture in the air is responsible for some kind of electrolytic process - then there's enough such moisture everywhere.  What I'm trying to say is that the quantitiy of moisture is so negligible that I suspect it can be entirely discounted.  But that's just my opinion.
If we can discover what makes these types of devices stop then hopefully we can understand more about what makes them go.
I agree with you if they work anywhere  then the question of moisture is almost redundant
Quotelasersaber has interrupted the rig twice, once to transport it to the site where it now is.  And once to adjust the magnet's spin.  It would be a shame to interrupt it again.  I think any further questions can be established around further builds.  Let's get this one going for a year - uninterrupted.  That would be SO significant
I totally agree with you on this, let it run as long as possible.
This device looks like it could be one of the best contenders for the OU prize
not necessarily for the prize but for the criteria of entry.
http://www.overunity.com/index.php?topic=5707.0
anyway a lot more development needed to get to that stage
All the best
cat
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
cletushowell
You may have a negative opiinion of me you
may think everything i know and say is impossible
but please just try to listen
gravity = magnetism frequency temperature
radiation= light or frequency
This coil is not a battery it absorbing
radiation from the air like a antenna
transfering it to energy
So how do you stop radiation
ill tell you water a shit load of water
if you soak that coil in a bunch of water it will
stop why?
Water prisms light and frequency
and will interupt the flow and direction
the coil is directing the frequency to the motor
coral castle says not to much girls
meaning not to much water just the right amount
determines to much or not enough
the birds dont fly very good on really hot days
in fact the runways in airzona have to be calculated the length
based on the air density
the birds fly the best before the rain
the highest level of humidity
without water
if you find the frequency with the most power or
i beleive you on the right track a bunch of salt crystals that pick up all frequency or a all wave antenna
with right amount of humidity i beleive you can really increase this power level moray had 50ft cable and a tuned ground to
water and a tuned antenna to salt granite or germanium
cells in a wood box to store the frequency
the wood has a humidity water barrier
i did 2 volts steay from a antenna to my salt cells
i dont know how to wire like lid or lasersaber
but i frien deep cell marine bayteries
if you start power thru the rod before you build it as you build it i do not beleive it will rust i think it only oxides during tbe phase it has no energy flow
my opinion. Take it for what its worth
most think im insane some think im genuis
me I think im lost has anyone built a giant
stubblefield does the power increase in size
or just in parrallel series
powercat
Hi cletushowell
please try not to take things so personally, this forum is not a personality contest, I have read many of your posts on this site before, and a lot of what you are saying makes logical sense, you are a knowledgeable person,
though your style of often aggressively preaching your point to people, makes me shy away from any communication with you.
Please try not to start an argument with me, I am here  to learn about the "Self-Runner NS Coil Pulse Motor Live Video Stream.  It's been going for months!"
And hopefully one day make my own version.
cat
Rosemary Ainslie
Quote from: Omnibus on September 04, 2010, 12:02:11 PM
Like I said, this should be discarded out of hand. A motor powered by a galvanic cell is trivial. Some basic competence is needed before getting into OU research and making big claims otherwise you fall easy prey to the zealous activists.
'Zelous activists' LOL.  The simple truth is that we're all victim of your own zelous irrelvancies.  I've tried to work out what actually motivates you Omnibus.  I'm now entirely satisfied that you're essentially so self-opinionated that you actually consider your every thought above question.  A motor powered by a glavanic cell is only trivial if the amount of energy delivered equals the energy dissipated.  And I see nothing TRIVIAL in the unique battery configuration that Nathan Subblefield devised.  It shows an extraordinary insight and some really excellent lateral thinking.  And the use of pure water to generate any kind of electrolytic action is far preferable to acids and such like which are pollutant and dangerous.   Added to which there is an elegant simplicity in the design that puts paid to regular battery constructs.  It's breathtaking.  And all you can do is DISMISS IT?
That's the original Nathan Stubblefield concept.  Now we've got lasersaber's variation.  NO WATER REQUIRED.  What do you make of that Omnibus?  :o   Are you even capable of wrapping the implications around that censorial, self opinionated, arthritic mind of yours.  I doubt it.  It would require a lucid mind and a certain amount of independent thought.  You're capable of neither.
'Some basic competence' as you put it - is also essential to learn to give credit where credit is due.  You stated that this experiment has no significance to any OU research unless there's no 'galvanic action'.  WELL THEN.  Prove to us mere mortals that there is such and I'll bother to study your opinion with a little more attention. But with or without galvanic action there is a remarkable simplicity and elegance that would, admittedly require a certain amount of insight to appreciate.  Clearly you lack this.
Rosemary
ADDED
I apologise to our members for being harsh - but the fact is that there's such extraordinary brilliance in this build and I'm rather ashamed that it is NOT drawing the attention that it should.  Then to add to this evident lack of excitement is the predictably fatuous comments from Omnibus and it's rather more than I can manage.
In any event I've toned down the post.  Hopefully this edit will take and that I'm not too late.
