Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
Pirate88179
Thanks Rose.  Well, it is not as good an idea as what Lasersaber has done using what NS had available to him at the time.  I had no shorts and did get a decent output so, I know this method works but, I highly recommend Laser's method as it is as close to what NS did that we can do today n my opinion.
If you do this, just make sure it is 100% cotton cord and not some percent plastic, vinyl or polyester.
Bill
dllabarre
Here's what I'm going to try...
1) Wind iron wire with a spacer thats a little larger than the copper wire (sting or use insulated copper wire for spacing).
2) Remove (unwind) whatever you used as the spacer.
3) Put a layer of cotton over the iron wire.
4) Wind the bare copper wire over this cotton layer between the iron wires where the spacer left a groove.
5) Then wrap a cotton layer over the bare copper and start the second row of iron wire.
I don't know how well this will work yet.  It's just a thought I had last night.
DonL
Pirate88179
Don:
That should work but, the cotton cord may be easier.  The best is the cotton covered wire but, kind of pricey in my world over here.  Let us know how that works out for you, it sounds interesting.
Bill
IotaYodi
QuoteIt may be that the cotton is providing this space resulting in some kind of capacitance to enhance the effect.
You have some capacitance already in the parallel coil wires. The damp cotton dielectric should be an added capacitance or place to build up charge. Think of an old time rolled paper capacitor. The patent states to have a continuous interposed layer of cotton. I haven't seen anyone do a full interpose yet or it appears to me they haven't. This would increase the area of charge and make the coil larger in volume with every wind. I think I may understand Stubblefields comment on the cotton covered iron wire now. If you use cotton covered iron wire without the interposed cotton layer it still works. But the area of charge is not as great. Using cotton on both wires with the interposed cotton would give more area of charge.
Comments needed on this line of thought.
What I know I know!
Its what I don't know that's a problem!
powercat
Hi IotaYodi
I was wondering about the suggestion made by Dllabarre,and then I saw your post about more cotton
being better
The above suggestion by Dllabarre  gets around the expensive cotton coated wire, and you end up with more layers of cotton, which could be a good thing.
Is it a good idea ? let's hope so.
cat   PS I remember reading about using welding rods in Bedinis to make a central core. Any thoughts on this
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
