FUELLESS CAR PROTOTYPE by ISMAEL MOTOR
Started by luishan, September 08, 2010, 11:50:07 PM
konehead
Hi Qwerk
No i am saying its similar in his repelling-tech is all. (the cascading DC circuit) I dont know exaclty how he does it but assume coil-shorting is involved in it too, and your links doent mention coil-shorting so they are only similar. The MEG is similar to HUBBARD coil if you want to study that.
forest
HOW DO YOU KNOW THAT ???? Nobody saw Hubbard device in action and detail, and even if same had seen they are dead now....
Qwert
Quote from: konehead on October 21, 2011, 11:34:01 AM
Hi Qwerk
No i am saying its similar in his repelling-tech is all. ...
Thank you Konehead, that's what I wanted to hear. Those generators don't give real power, only very high voltages; they need something else to get power. That means that my understanding is correct.
konehead
hi Forest
There is lots of information on the web about the Hubbard coils with modern drawings and illustrations and all sorts of stuff.
Just google it and look around for a couple hours and study it if you want (or not)
Ismael told me that his MEG is very similar to the Hubbard coil at least in some parts and functions of it - so whatever you see on the web about the Hubbard coil is also similar to Ismaels MEG - I will guess the multiple coils part of it and the arrangement of coils are the similarities.
konehead
Hi Qwert
Part of the circuit with funciton of filling a cap to 7500VDC very quickly (12 seconds after each coil blast) using a 9V battery and two AAs as power source in Ismaels "repelling force" coil blaster might be similar to a Marx generator type of DC cascading circuit - might not be too - Another way to contribute to the fast cap-filling is multple coils shorts and sinewave peaks like I described where the oscillation-peaks created by intial short are shorted at THEIR peaks  - this will put HV into caps super fast - maybe then, a DC cascading circuit is also used too in combination with peak coil shorting circuit  (dont know but why not)
