My free energy experiment.
Started by stevensrd1, September 12, 2010, 11:07:25 AM
stevensrd1
Yep,,it recharged the battery to 9.73volts and I redid it again today just for kicks, I took the battery off the inverter just to test the voltage and it now reads at 9.83volts,,and connected to the inverter, since its still recharging,,it reads at 10.00volts
I did completely drain the 9v battery on a small motor before this test until it ran no more, then I left it connected to that motor for some hours till I could not even get a tingle on my tongue from the battery. The 12volt inverter works at 6volts with 4 AA batteries. And fully recharges my 9volt rechargeable batteries. I did mention it is a small 12v to 110v inverter,,max 5watt, its small,the kind that fits in palm of your hand, plugs in a car lighter. While its working you can see its red light on dimly, and if you accidentally touch the ac output of the inverter as I have lol it will shock the crap out of you...
nievesoliveras
Can you post a schematic of your charger configuration using an inverter?
stevensrd1
OH my,,Im not sure I can, I will post a few pictures, as to the schematic,,im not looking up the resistor colors and the the transformer has no markings on it, the board itself does have markings on it,,it says HYS-CA01 ZHONGMAOWEN. There is 13 components on the board, and I bought it on ebay. On the outside of the case it says car charging power converter Output 100v-240v limited for DC 12v car only, Ill post a pic of the front and back shortly.
stevensrd1
Here is a pic of the front of the 12v to 110v inverter.
stevensrd1
Here is a pic of the back of the 12v to 110v inverter.
