Obsure Reference YOU CAN BUILD GEET Reactor SAFE
Started by Hope, September 22, 2010, 01:03:18 PM
Hope
)) Smiles to you for your correct observation,  when radiant energies combine we can make things not normally seen happen.  This is how life and the universe works.  Some times we KNOW what will happen other times something DIFFERENT happens.  Go figure!      We can make OU also, like nature does so often.    It is not FORBIDDEN as so many seem to believe.  IT IS SUPPRESSED!!!!!!   Make This Dream an opportunity!    Try this device,  Let us smash this ignorance and regain control of this fear munging fed admin.  Soon we will all find this truth to be self evident, why not NOW!  As far as I can glean you will at least get 30% to 60% better mileage, so what is the harm.   Get them fears buried,  lets start getting BACK in control.
edited
Hope
If misdirection is an indicator,  then this topic which was hijacked to CORN BOILERS must be a threat to the GAS company.    All we really said was magnetically zap all components before trying to resonate them.  Then resonate coil one and three 180 degrees out of phase.  THEN capture the OU on and in between coil 2.   WHAT   this sum sort of threat????    I wonder why?        I have NEVER posted or read the CORN BOILER topic, thou this thread was sent there for replies.  UMMMMMMMMMM?    Maybe this works like all who have FOLLOW the specs say it does.???
happyfunball
Quote from: Hope on September 24, 2010, 12:59:52 AM
It wasn't corn boilers, look at earlier pages in the thread. Tommey Reed built a GEET and showed it was simply a vapor carb. The extra pipe within a pipe did nothing, other than generate heat and waste energy. It was a series of maybe 20 videos, with test results. I don't know why his youtube channels continuously disappear, it's frustrating.  the latest one is http://www.youtube.com/user/FreeEnergyNow1  but the full geet test isn't there.
tagor
Quote from: happyfunball on September 24, 2010, 01:52:15 AM
yes Tommey Reed understood that it was not useful !!
there is plenty of replications in france !!
Hope
Your correct about Tommey Reeds claiming GEET doesn't do anything except dry vapor the fuel (multi fuels even).   But on his test rig he ONLY has a pipe and bubbler NO GEET.   Even then it runs off fuel vapor that is mixed with a lot of water.    ?????  I can live with dry vapor fuel from water with gas in it.   Then Reed claims that no work can be done (with the engine RUNNING and LIGHTING 1000 Watts of LIGHTS)  I guess Tommey is using negative logic to show it works!
