Obsure Reference YOU CAN BUILD GEET Reactor SAFE
Started by Hope, September 22, 2010, 01:03:18 PM
happyfunball
Quote from: b0rg13 on September 26, 2010, 02:16:40 AM
hi man can you start a thread about vapor carbs and throw some links in ?.
..i dont mind be educated.
It's simply a bubbler carb. Whereas normal carburetor function is to mix air/fuel pre-combustion, a vapor carb converts the fuel to vapor through agitation with water. Tommey built one, they haven't often been used. Google will return as much info as you need. Paul Pantone claims the GEET will run on urine, ketchup, anything carbon based. He's a con artist liar. In reality, these substances sink to the bottom of the vapor carb and stay there, while vaporized gasoline fuels the engine.  Pantone has made a tidy living off bilking suckers out of their money for his worthless GEET plans. T.Reed challenged anyone to prove him wrong, no one stepped forward. Considering the multitudes of youtube videos claiming GEET works, you'd think it would have been a simple matter. It wasn't.
Hope
So what your saying is an Anton cell coupled with a reactor would not enhance into a self running system.    I just wanted to show you why devices like this will add to self running systems.   The GEET takes money out of oil profits so it is a threat.  It can use many fuel types.  We can take an Anton or Meyers cell and couple its technology with Nadin reactor and do work with mere water.  The greatest rub is people discouraging others NOT TO TRY.   EVEN (i repeat) if I only gain 10/20/30 % and burn cleaner this is a good step.   Gate this Geet gas thru a KingFisher valve (throttle plate reeds) and we have a larger threat = automobile usage.   I firmly believe that COMBINED technologies will move us closer to our goals.
Hope
And Borg there are old and newer models of these devices.   They are useful and with a finely controlled heat source will serve as a multi liquid micro refinery, at least this is what MIT pattened it for (20% change I guess from Paul's).
edited usage
Hope
Ok all,  I have 90% of my reactor complete and have a welder interested in this project.   He says the weldable pipe pieces are MUCH cheaper (of course he welds) and has agreed to weld the next reactor.  Hunting season is busy for us (we don't hunt but our friends need  our help)so we will be busy these 2 weeks.   JL Naudin seems to have even a water spark plug working.  Amazing.  Naudin now has a mower that is shown running on tap water.  He mows the lawn even.   That engine sounds great!
ramset
Hope,
Do you have a link to the mower that runs on water?
Thanks
Chet
PS
Jesus
In your post #30 on this thread you show what looks like a geet reactor?
Is that your design? anymore info would be appreciated!
Thanks Grandma
