Electricity Amplification Device - It's so simple !!! (Hatem Magnetic Cogging)
Started by bimbothova, October 13, 2010, 11:40:13 PM
Low-Q
Quote from: bimbothova on October 13, 2010, 11:40:13 PM
All the info you need to build a successful overunity device or in other words, an electricity amplification device, is given on this Peswiki page ...
Kudos to Youtube member 'MindFreer' who has uploaded a complete guide book video on this technology ...
http://peswiki.com/index.php/OS:_Hatem_Magnetic_Cogging_Device
Many hobbyists out there often have lack of knowledge, and do many times believe they add 2 x 2 and gets a product greater than 4. Yes, it is possible to make readings of voltage and ampéres which in the first plase looks like it makes more energy out than in. But in such cases there is a given phase shift which is resulting that voltage and ampéres are not syncronized in time.
An example:
A person makes this device, and measures 10V and 10A input. Then he loads the output and read 20V and 20A. Any person with a common sense "understands" there is 400W out - or are they wrong? What they overlook is the phase. Say the real input are both volt and ampére in phase; 10 x 10 = 100W. The real output are in best case (20V x Cos65) x (20A x Sin35) = 97W - take this as an example. Now you can try to loop the device and try to feed 97 Watts into an input which require 100 Watts to run. This is the very reason this particular device cannot bee looped, and ran by itself. The explanation are all there. There are no energy from space which is harnessed by a magnetic coupling. It is all about the relationship between the VA-readings and its phase.
Vidar
exnihiloest
Quote from: bimbothova on October 15, 2010, 12:48:19 AM
The beauty of this design is that ... you can start a chain reaction by adding more rotors adjacent to the rotors installed next to the PRIME MOVER ... I foresee huge electricity generation FARMS based on this technology.
Beautiful, like most of the products of delusion.
gauschor
Hmm looks interesting, anyone tried the Bobby Thomas "optimized" version? Though I'm afraid this version could produce asynchronity because the magnets on the rotor don't force a "path" (contrary to Hatem's device with 3 rows of magnets which force a "path") and probably if the main rotor speed is too fast one pole could be missed.
Also will it still work as well if dynamos are attached... which need additional effort. Hmm speculating only... and then we'd need a load that needs more power than the source to really prove it :s
