Simple(?) and cheap OU-test
Started by lancaIV, May 02, 2006, 09:36:50 PM
pg46
was just wondering then -
if one ignored the brightness or dimness of the lamps for a moment - will one have enough power to run say an alternator at the end of the line of the lamps in series?
In other words, does the more lamps that one connects in series give you more available current at the end of the line?
pese
Shur , this is an "bug" it this items will give "ligt"
its no but if 50 lampt (from 230 vols (each blub becomes only less the 5 VOLT ,
wil no give any lght !!
only 50 time some watts in infrared heat.
Its only an bank of resistors with unlinear ressistance , of the wolfra wire
because the condutivigie is different is it?s colf , red or full lightning.
(se this metal table book , it must be in.
even if vou take only 2 lams 200watt each , and  each with 115 volts , the both together will not bring
the light of  1 single 200watt blup at 230 volt.
try it with "lkuxmeter"  or calculate them .
its to simpel , to find any "esotheric power in this idea".
electronic , calculating that is describe , no see that
any additional blub will degerase the lightning voltage
of each blub , and degerase the lightning effects up to zero.
its not so  good to power watts in , and not ligt come out.
(only heat) with NO Overunity !!!!
gyulasun
Hi Lanca and all,
Fortunately there is the English version (I cannot speak German) of the two patents you referred to (FR701188,page 3 =AT127608,Seite2,Zeile33) and  this patent is  GB368249 and the text you mentioned (HF-conditioning) says:
"In Figs. 3 and 4 two arrangements of connecting the units consisting of induction coils and luminous letters or other representations in series are shown. The connection of the units in series has the advantage over the previously described connection in parallel that a greater number of units can be connected to a source of high frequency current of given strength under the retention of the same lighting power of the luminous tubes supplied therefrom when the connection is in series than when the connection is in parallel."
Though this text clearly claims the advantage of the series connection of the given setup, and this setup includes (glass)tubes filled with rare gas and embraced with Tesla coils and all this MAY INHERENTLY include the possibility of overunity in the special arrangement shown in Figs. 3 and 4,   the Kovac' patent do not mention anything that may inherently be connected with any 'overunity parts or arrangements'.
You included Dragan Kovac's phone number in another post here:
http://www.overunity.com/index.php/topic,922.0.html  and I would like to encourage anyone German speaking member here to making a telephone call to Dragan Kovac to inquire on the "know-how" if it is possible. It is obvious that Kovac did not include the 'secret' in his lamp arrangement and seemingly patented the series connection of nonlinear resistors (incandescent lamps) which would be ridiculous in itself!
Gyula
