Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
romerouk
Quote from: majkl on November 11, 2010, 03:07:40 PM
Hi!
This is not about captret... but if you can help me...
I try to replicate this Dr. Stiffler's experiment. -- see the diagram and table with his results.
I have electrolytic capacitor 100uF/100V and Avramenko plug with 4 diodes 1N4148.
My result after 40 hours is that a capacitor is charging but very slowly...
time:
0 hours -- cap: 0.343 V
6 hours -- cap: 0.388 V
16 hours -- cap: 0.436 V
40 hours -- cap: 0.522 V
Can anybody explain me why my capacitor is not charging same speed as Dr. Stiffler's capacitor?
Do I need more diodes in series? Why is more diodes better?
Thanks ;)
--michael
Make sure that no light goes to the diodes (cover them with something) then start measurements again.
All the best,
RomeroUK
Kator01
Hello michael,
I think it has to do with the ground-connection which is different in each house. The neutral-line is connected with the ground-line ( in german-speaking europe we call it mass-line ) behind the main fuse-box of your house. So this physical point must be very well connected otherwise an ac-component which is induced  by the hot-line in the neutral line builds up. This is so because the hot- and the neutral line run parallell very close together. This ac-component is called loop-current and should be as low as possible. If the connecting point is in bad shape it has a higher ac-resistance any induced ac-current in the neutral-line cannot flow down to the ground via the groundline. This loop current oscillates between neutral- and ground-line from the connecting-point upwards to your wall-socket and I think that this is the current which charges your cap via the Avramenko-Plug.
So there is nothing you can do about it as it seems that your connecting-point is in better shape than the one from Stiffler´s house.
How to measure the loop-current ? Take a digi-meter switch to AC-mode and measure between ground-plug and neutral-line-plug. What does it read ? Millivolts or even volts ?
Kator01
majkl
@RomeroUK: Thank you. There is no change with the diodes covered. (Does a diode work different under light? I don't know this... (???)
@Kator01: Thank you! Between the ground and neutral line is 72 mV. Is it low?
And I still don't understand what is a difference between the Avramenko plug with just two diodes and AV-plug with more than two diodes?! (Stiffler has 18 diodes as AV-plug in some diagrams. - Why?)
--michael
Goat
@ All
I just posted a circuit that needs 1.5 VDC to power it at http://www.overunity.com/index.php?topic=6763.msg263776#msg263776
I wonder if this circuit could be used in charging up a super or ultra capacitor in order to run the above mentioned circuit.
If anyone has access to a  super or ultra capacitor and is able to see if it can be charged by the captret circuit it could be a way forward to OU for us all.
Any and all feedback from everyone is welcome.
Pal
fritznien
Quote from: majkl on November 11, 2010, 09:04:36 PM
--michael
most semiconductors are light sensitive and photovoltaic.
if the diode cases leaks light it can act as a solar cell.
fritznien
