Sonoluminescence - mini sun in bubble, intense glowing blue light with sound.
Started by energia9, October 27, 2010, 06:39:40 AM
gravityblock
Quote from: mscoffman on October 28, 2010, 11:48:37 AM
Despite what the film indicates;
The blue light from hydrogen in water vapor in the vaccum cavitation
bubble is indicating there is sufficient energy for the hydrogen isotope
Deuterium [2]H, chemical symbol D, to fuse, but not sufficient energy for
the standard hydrogen [1]H itself to fuse.
So the light is not really from
the fusion energy, but is called diagnostic for D+D fusion. The same thing
is true for the pistol shrimp except that the pistol shrimp really does create
some excess energy and some of it's flash may be from energy generation.
Exactly how in terms of physics equations the D+D cold fusion process
occurs from the bubble's electrodynamic behavior is not currently known.
A metal matrix target may be necessary to have the two D atoms be in
the correct geometric arrangement for cold fusion to occur. Part of the
problem is something like 80% of Physicists work at high energy particle
accelerator laboratories and so can't be bothered with these mere energy
generation studies.
:S:MarkSCoffman
I believe you're correct about fusion being generated with deuterium.  Below is a quote from an article titled, "Sonoluminescence: A Star in a Jar", saying fusion is possible with deuterium on page 40, http://whoisyourcreator.org/assets/PDF's/sono2.pdf
"If the bubble contained deuterium, it would become hot enough to generate fusion if the radius became as small as 10nm."
GB
energia9
theorizing is faar not enough, someone hopefully starts to think about this project,i cannot start it as im experimenting with longitudinal electricity, creating sonoluminescence it is not so difficult, you need a good logic pattern, and some info on nuclear magnetic resonance charts and calculations of the oscillations. making fusion would be the second thing after you done with this, step by step friends, and perhaps other things could come out of this, artificial gravity engine (anything we dont know)
regards
energia
energia9
Quote from: energia9 on October 29, 2010, 03:25:55 AM
regards
energia
i believe that we can get huge energy from water, it is the most abundant element in the universe(told by our scientists)  if we would be able to split the atoms of water in the way that we can still convert it back to water,   it is the nuclear magnetic resonance of water that we need to research more,   check this out   http://www.eclipse.net/~numare/h.htm
Isotope: 2H
Spin:                         1
Natural abunance:             0.015%
Magnetogyric ratio (rad/T s): 4.1066 x 10^7
Relative receptivity:         0.00000145
Magnetic Moment               1.2126
Quadrupole moment Q/m(2)      0.0028 x 10^28
Resonance frequency           15.351 MHz
If you try to look at other sites, they all write on different resonance frequency, because water hasnt  got just one, and it well depends on the magnetic field it is subjected to aswell!
gravityblock
Quote from: energia9 on November 27, 2010, 07:07:45 AM
Isotope: 2H
Spin:                         1
Why would you want to have fission, when fusion is possible?  Not only fusion is possible, but cold fusion that doesn't release radiation.  I suggest you take a look at the ground breaking work of Frank Znidarsic explaining anti-gravity and cold fusion in detail, http://www.peswiki.com/index.php/Review:_Anti-Gravity_/_Cold_Fusion_Explained_In_Detail:_A_New_Era_in_Physics
The condition for anti-gravity and cold fusion is slowing the speed of light in the electronic structure to match the speed of sound/mechanical waves in the nucleur structure.  The speed of sound in the nucleur structure is 1,094,000 m/s, which is the quantum transitional speed.  I would also think about using deuterium.
GB
gravityblock
Single Bubble Sonoluminescence HOWTO, http://www.macgeisler.de/nld/sbsl-howto.html
Quote from: techmindReports are abound (on the Internet etc.) that sonoluminescence requires at least an 100/200/300... Watt amplifier. In fact typically only ONE watt is dissipated in the transducers/drive system during sonoluminescence. More "powerful" amplifiers are really only being used to overcome bad matching by brute force, by providing more raw voltage swing - it's not the available power that counts!
http://www.techmind.org/sl/
GB
