UCVC
Started by resonanceman, November 04, 2010, 10:50:12 AM
resonanceman
Quote from: nievesoliveras on November 04, 2010, 05:19:00 PM
Is this just the secondary of the Joulethief?
Jesus
This   circuit is for controlling voltage going to a Ultra cap.
The coil circled in red could  be called a secondary of the JT.
I added this  winding to a JT charger I already had.
I plan on  testing  a way to use this circuit with a JT charger that has no room on the toroid  for another winding.
Soon I will  switch to a schematic that shows  the JT charger and the voltage control circuit.
I wanted to try to keep  it as simple as possible at first........so I only did the voltage control circuit.
gary
resonanceman
My goals for this circuit were
Low parts count.
Common parts only.
Charge indicator light , so I can gauge the  approximate charge level at a glance without a meter.
gary
resonanceman
A few more details about this circuit.
A relatively large transistor is needed.
I tried a 3904 ........I could  not get it to work.
So far most of my tests have been with a TIP2055
I tried a MOSFET ......couldn't get it working........yet.
I use several meters when  expermenting  with this circuit.
I monitor  the voltage of the primary of my JT charger.
I also monitor my supercap voltage and my charge battery voltage.
I am not currently  trying to feed back to  the JT battery
This circuit may be easier to make using a candy cane  type JT charger.... with the candy cane  coils it is very quick and easy to add the secondary  for this circuit .
The  secondary I am currently  using is pretty much identical to my primary winding on this charger.
Both go through the centers of all the toroids.
I stopped using this kind of secondarys a long time ago because this type of secondary will always take  priority over the other windings....... it is just to powerful to co exist with the normal secondarys.
gary
nievesoliveras
Thank you @resonanceman!
You have quite a project there.
The mosfet has to be driven by a small transistor like 2222A or similar.
Jesus
resonanceman
Quote from: nievesoliveras on November 04, 2010, 11:17:26 PM
Jesus
Jeasus
Thanks
So if I understand right  you are saying that the mosfet setup would  have to be kind of like a darlington transistor?
I am still pretty new at building things ......and maybe a little slow.
Can you draw a schematic  of how the transistors would  be  wired?
I think MOSFETS would be ideal .......but  the fact that  they have little or no  current flowing through the base eliminates the LED indicator light.
That is really not a problem  because  the right sized coil added in series with the control  coil could  be used to power a LED whenever  there is  current  flowing through the  control  coil. ( I have done this on a few  charger circuits I have made )
gary
