The homotenna (homopolar motor + antenna).
Started by broli, November 08, 2010, 06:32:10 PM
gravityblock
Broli,
On pages 136 & 137 (see snapshot below for a quick reference), Faraday talks about the 'center of motion'.  He says when the magnetic pole is on the outside of the center of motion, then the wire piece will move in a direction directly contrary to that taken when the pole was on the inside of the center of motion.  How does the wire piece know if the pole is in the inside or the outside of the center of motion in order to know which direction to move?  It's because the wire piece doesn't run directly parallel to vertical.  For example, when the pole is in the inside, then the wire piece will be like this / |, and when the pole is on the outside then the wire piece will be like this \ |.  This means there are now 3 ways to change the rotation direction:  1.)  Reverse the poles.  2.)  Reverse the polarity of the current.  3.)  Reverse the center of motion.  IMO, this is extremely important and can be used to our advantage by having 2 rotating wire pieces, each having a different center of motion around a different magnet.  By simultaneously reversing the center of motion for both wire pieces around a different magnet with an opposite pole (or reversing the current with magnets of like poles), then we can have the rotating wire pieces run in a 'figure 8' pattern.  This is equivalent in having at least one lead to always be 'physically shielded' by an infinite length!
Thanks,
Gravock
gravityblock
Quote from: gravityblock on September 03, 2012, 03:33:03 AM
Broli,
The 'figure 8' is the symbol for infinity.
Gravock
Perhaps if you can you should sketch/draw the concept so I can see what you mean more clearly.
gravityblock
Quote from: broli on September 03, 2012, 06:27:22 AM
Broli,
From an engineering point of view, It may be too complicated to have the wire pieces run a 'figure 8'.  However, here's a sketch based on a change in the center of motion according to the original Faraday experiment.  The sketch somehow took the shape of a starship, lol.  The gold conductor should rotate CW on the gray vertical shaft.  The green arrows are showing the direction of current flow.  Please note, this should work without a stationary external circuit and without any brushes.  The effect should be equivalent to shielding one lead with an infinite length.
Gravock
gadgetmall
Broli Will and others . Hi guys . Miss you and great experiments and Kodos on keeping Sharp . And Wiley i owe you thanks because if not for you and your first experiment on the beginning of jule thief thread with the fl tube i would have just gave up so you gave me my first real  inspiration . thank you . I know there are still trolling going on. Seems more so that when i left sick a few years .
I know this is fake (Pretty sure after 1000's of experiments with coils and magnets) but i responded to the thread
solid state free energy device thread . Poor guy wasted a saturday on this . Its a coil center tapped with an antenna and a hard drive magnet
Should this be part of this Experiment and discussion ?
http://www.youtube.com/watch?v=yoCBORXzOqU
I Don't know  how this guy faked it and his 16 other videos look proper . Most of us know that there should be a hidden power source but where ? First i thought is was a super cap in the motor but that don't explain the soldered alligator clips on copper wire (short) producing almost 6 volts dc with his glued harddrive magnet . I dont see a button cell and if there is a button cell how can it go thru two soldered shorted clips . He walks thruout his property taking measurements and the volt meter still shows the same volts . WTH ?Also the powerline theory or cell phone radiation don't hold either because the voltage shown on his meter is dc and the same anywhere he moves  so inductance is out . With all the fake vids now it is very hard to even believe anything anymore and that is not good.I have hear of CG fakery and such but this ?I know how brittle harddrive magnets are i don't see the hollow magnet theory here .
Here lately with ALL the fake videos i have tended to become somewhat negative and i don't want to be that way . My personality has changed from gadgetmall to gadgetmaul :) It's the medicine i am taking but my soul is still the  same .
I would appreciate comments on this . fake . then how ? no fake then how?
AND TROLL COMMENTS WILL NOT BE TOLERATED AND YOU WILL BE PUT ON IGNORE!
Gadget
