Overunity.com Archives
New theories about free energy systems => Theory of overunity and free energy => Topic started by: acclowyat on January 27, 2011, 01:46:09 AM
Title: self-sustain
Post by: acclowyat on January 27, 2011, 01:46:09 AM
Found this, any experts care to clarify?
QuoteCONCEPT OF SELF-SUSTAINING MOTOR ASSEMBLY
Presented here is original basic concept of Self-Sustaining AC & DC, Vertical & Horizontal Motor Assembly.
With reference to Figure 1, is shown the perspective of simple vertical variation of either AC or DC self-sustaining motor assembly A. As shown, the electric motor 1 and elongated generator 2 have common shaft 3, common two bearings 4, common frame 5, and common stand 6. At top of the shaft is attached a pulley 7 and string 8 with loose end 8-a. Shown further is the internal electrical line 9 connecting the generator 2 to electric motor 1. Also an output electrical line 10 of generator 2.The electric motor 1 has WIDER WIDTH 1-a than the generator 2., thus with longer leverage, stronger torque, capable of overcoming mass resistance that, even though the, advisably, hi-speed electric motor has, say, one HP, it is capable of driving, rotating, the much larger, say six HP generator 2 because of compensating longer leverage. As illustrated, the bottom shaft 3-a has oval shaped (or with installed roller bearing) sitting over the water-cool adjustable base 11.
The simple operation is as follows: Roll the adequate string 8 with loose end 8-a to pulley 7, then pull the string 7 until completely loosen. But in the process, adequately cause the common electric motor 1 and generator 2 to rotation, and for generator 2 to produce electricity, part of such electrical output is channeled to the electric motor 1 thru internal line 9 to cause said electric motor 1 to rotation and drive the generator 2 to rotation synchronously, and for the generator 2 to produce electricity to self-feed electric motor 1, etc. The other part of electrical output of generator 2 is channeled to its output line 10 for outside purposes, such as lighting household, driving electric fans, etc.
With reference to Figure 2 is shown horizontal variation of AC & DC motor assembly B. shown are the electric motor 1,generator 2, the common shaft 3, common two bearings 4, common frame 5, common horizontal stand 6, pulley 7, string 8 with loose end 8-a, the internal line 9 of generator 2 to electric motor 1 and to output line 10. The electric motor 1 has wider width 1-a than the generator 2. There is no need for base11. The simple operation is the same with Figure 1. This horizontal variation can be converted into electric fan by installing a fan at shaft end 3-d.
This self-sustaining motor assembly can replace windmill and sun light energy devices. There are many variations, as filed pending with Bureau of Patents, Philippines, re-variations with independent driving electric motor, with overlooking magnet preferably neo-magnet., with step-up, step-down feature, with driving gasoline prime mover, battery prime mover, either. DC brush or brushless.
Manufacturers are invited to construct at liberty and to market as cheaply as possible this one of the cheapest CLEAN ENERGY device, so that its very potential contributions at this accelerating energy crisis will be realized.
jsaldea12
2.28.10.
jsaldea12@yahoo.com
Jose S. Aldea, Inventor, .Chairman â€" Capiz Scientists & Inventors Society - Philippines
Alfredo A. Bisnar, Associate
reference  : http://www.thescienceforum.com/CONCEPT-OF-SELF-SUSTAINING-MOTOR-ASSEMBLY-23246t.php
Title: Re: self-sustain
Post by: DreamThinkBuild on January 27, 2011, 12:20:46 PM
Hi Acclowyat,
Welcome to the forum.
Does anybody know what is meant by "The electric motor 1 has WIDER WIDTH than the generator..."? It doesn't make sense to me if it is running on a common shaft what WIDER WIDTH means.
Thank you for the info.
Post by: e2matrix on January 27, 2011, 01:21:40 PM
DTB I think they simply mean the physical diameter of the motor is bigger.  At least the way I read it there are two motors but one acts as a generator.  Looking at the diagram it appears the motor is the shorter but larger diameter part.  It seems too simple to be true but I can hope this has real possibilities.  The fact that it comes from this source "Capiz Scientists & Inventors Society" is somewhat encouraging I believe.  However since it is listed on their forum under " New Hypotheses and Ideas " it doesn't sound like it has been built yet.
Post by: neptune on January 27, 2011, 01:23:17 PM
could it perhaps mean Larger Diameter
Post by: Airstriker on January 27, 2011, 05:50:22 PM
Oh dear, another bullshit.
