Overunity.com Archives
Antigravity Technologies => UFO sightings => Topic started by: raburgeson on May 20, 2006, 08:54:42 PM
Title: 4000 year old ufo
Post by: raburgeson on May 20, 2006, 08:54:42 PM
They recovered it from the grand canyon, there are crashed ones lying around, we have to find one. They haven't recovered that many there is probably a couple of thousand unrecovered right here in North America. If you see a ufo in the sky fine get a pic. But, you can't reverse engineer a pic, keep your eyes open for what we really need, a crashed one. Take camo net for the terrain your in when you go into rural and wild areas. Cover it an find help that doesn't agree with government policy. Watch out for orgs like MUFON and avoid them. The gov has all these type orgs intimidated. Have you heard of samples gone missing? I've been trying someone else give it a try, we need to convince these other nations of the truth, when they find a ufo reverse engineer it for themselves. Don't give it to the U.S.A. like an obedient dog! The USA is not sharing technology, it's hording it, and it's bulling and stealing. If it crashes on someone elses soil it belongs to them. I hope I convinced you we don't need another picture, we need to recover a ufo, speacially I hope I reached the divers in our group with this statement.
Title: Re: 4000 year old ufo
Post by: raburgeson on May 23, 2006, 03:00:20 PM
Divers would have a chance for three reasons, the best is unexplored followed by unmapped by spectro-analysis followed by many organic shapes have the relative form of a disk so it confuses previous searches. The down side is objects will be covered with silt, barnacals, coral, sand and even illegally dumped garbage. It's still possable one can be located on land too.
Post by: raburgeson on May 24, 2006, 05:25:01 PM
Now why don't someone get smart and seach "4000 year old ufo"" uso "" Intelligent Arial Craft" ebe craft or disk"" anyone of You figure out what the gov is calling them now? http://www.cseti.com/crashes/crash132.htm
This guy commited occupational harrycarry and talking about unavailible scientist;
http://www.abc.net.au/science/news/stories/s143053.htm
PrintPrint EmailEmail to a friend
Water on Mars - as recently as yesterday
Friday, 23 June 2000
martian gullies
Image taken by Mars Global Surveyor on 22.1.00 showing gullies (3 km wide) in the martian southern hemisphere which researchers think are due to an aquifer less than a few hundred meters beneath the surface. (Pic: NASA/JPL/Malin Space Science Systems)
While researchers have long suspected water existed in the past on Mars, new visual evidence suggests it might have flowed on the red planet as recently as yesterday.
Images to be published in the 30 June issue of the journal Science show new landforms, never before seen on Mars, which researchers think is evidence of a ground water supply, similar to an aquifer.
"We see features that look like gullies formed by flowing water and the deposits of soil and rocks transported by these flows. The features appear to be so young that they might be forming today," said prinicpal investigator, Dr Michael Malin.
The gullies are on otherwise geologically young surfaces which lack other landforms such as impact craters which would suggest an ancient landscape. The images taken by the high-resolution "eye" of the Mars Global Surveyor show steep-sided gullies, sinuous channels, and deltas of debris and suggest that liquid water may be lurking at shallow depths beneath the martian surface.
The presence of liquid water in the upper crust of Mars could be a boon for future human expeditions to the planet that could use the water for everything from basic survival to fuel cell energy and rocket propellant, the Science authors say. Some scientists believe that if life exists on Mars, it will be found in or near a water source.
Pic: NASA/JPL/Malin Space Science SystemsThe researchers calculate that seven community swimming pools worth of water was necessary to transport the amount of material seen in the debris fans. However the challenge has been to explain how any water on the martian surface could have survived evaporation under the sizzling martian temperatures, long enough to create the gullies.
Malin and colleague Kenneth S. Edgett suggest that the water exists in a porous layer of rock buried a few hundred meters below the martian surface, kept liquid by the pressure exerted by overlying rock. They propose that water seeps through the porous layer until it is exposed at the surface inside a crater or other depression. These first exposed trickles may freeze into a small ice "dam" at the surface. Meanwhile, groundwater continues to percolate through the rock and build up pressure behind this ice dam, creating a reservoir of fluid that eventually bursts through the dam and runs downslope, like the surge of flash flood waters.
If this is the correct scenario, the researchers suggest that the formation of the martian gullies may be linked to their location. Most of them occur in locations that get the least amount of sunlight in the martian day.
"There's still a finite chance that they were formed some other way," says Malin, "but there's a high probability they were formed by water."
The research team now plans to continue surveillance of the landforms to gather more evidence to support their water hypothesis and to see if they can catch the gullies in action.
Amazing what scientist say when they get left out of the action.
Note the sizzling temperature part. Ice caps at the poles, there must be some moderation in between Sherlock.
Other observations  If the atmosphere is dusty it probably was from yesterday.
Post by: mikestocks2006 on June 01, 2006, 10:46:33 PM
According to these depictions and interpretations, the sightings and attempts to document them go way back, some 29000 years ago, some 15000 years ago etc.
What's really interesting is that certain shapes remain the same for tens of thousands of years!
Some pretty nice attempts to depict what they were seeing!
http://www.ufoartwork.com/
Post by: mikestocks2006 on June 09, 2006, 08:47:28 AM
Some other interesting ancient technology
These images were found on the ceiling beams of a 3000-year old New Kingdom Temple,
located several hundred miles south of Cairo and the Giza Plateau, at Abydos.
Where did the people who carved the depictions get the images from?  Some theories may say time travel? Parralel universies? who knows...
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.crystalinks.com%2Fhieroplanes.jpg&hash=531c75636d0cffcc16ea1c11d4c1ec80fddbf905)
3000 year old
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.crystalinks.com%2Fheirohelicopter.gif&hash=e66e1ca514c1f8b00fbc79bdaf47d9a332f95191)
compare to todays
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.crystalinks.com%2Fhelicopter.gif&hash=b4a6266652aa449e71d46652dd9ae0b5d672abff)
more here http://www.crystalinks.com/ancientaircraft.html
also
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.crystalinks.com%2Fegyptlightbulbs2.jpg&hash=8179407c800764e617cc5797a79ef8d009832561)
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.crystalinks.com%2Fegyptray.gif&hash=41202641a11f3953088a1eaea289e5de0d0b5611)
http://www.crystalinks.com/egyptscience.html
The photo below is of another gold pre-Incan figure.  It is angled so that the non-zoomorphic characteristics are easier to see. http://members.tripod.com/TheUnexplainedNet/Page7tr.htm
Does it look like a modern day delta wing airplane?
Post by: raburgeson on June 09, 2006, 03:15:47 PM
The most remarkable thing about those glyphs is the fact that they were found underneath a wall that was resurfaced after the resurfacing gave way. I haven't seen a conformation on the date of the particular suface yet. Check out South American Gold toy areoplanes that have been found in grave sites. The last pic in your post looks like directions on using the tuning forks that were found. The forks were made of (steel?), and they found batteries and complete directions on making a light bulb that was built and worked.
Post by: magpower on June 09, 2006, 03:25:59 PM
http://www.philipcoppens.com/bbl_plane.html
Hey have a look at this, I think we have a long history
Wayne
Post by: raburgeson on August 03, 2006, 05:07:11 PM
It was very hot this weekend, we were hunting the national forest with metel detectors. We didn't find anything ufo But!, we did find a large deposit of Hemitite. Being a metalic composition I suppose it's an indication the group really is searching. I want to report an oddity. It may be a wrong statement but it was so weird I got to mention it. One o'clock A.M. I got up to go find a bush. I didn't have a shirt on. It felt like the sun was shining on me. I got the rest of the group up. They agreed with me. Heat seemed to be radiating from above. If I had my eyes closed it felt like it was about noon. We thought the ground was probably 90 degrees and heat radiating should be felt coming from the ground. Then we thought we might be being tricked by deep sunburn tingle. We were under trees all day long, that didn't fit. So I'm telling you about it. Hope someone double checks this, it's just to weird. We got coast to coast listeners here so, I thought someone could fire up a boom box and sit out in the lawn chair and see if they notice this. Just do this during a heat wave we should get another one. I have talked to people that work outside they say I could be right. Well 5 square miles down, half a million to go, it's going to take forever, we hope to get more people involved. We are trying to get a diving group here interested in scouting the bottom of the lake too.
Post by: raburgeson on September 11, 2006, 08:59:56 AM
Unfortunate, a group has found a f89 that was missing that appearently was chasing a ufo. A huge tear drop object is beside it, they are the only objects in the area. The people involved have a big mouth and can't recover this until next year. This object will never reach civilian control. I tried to get divers interested in hunting, infact a previous post in this topic deals with this. We have been searching in the National forest here and have not even thought of looking at the state forest. We lack man power and maybe have covered 15 sq. miles so far. We are marking the area covered in a nondisclosed manner. We need one ufo hidden in a safe area. We need it reverse engineered by non scientist, nongovernment affiliated personell. These can be gotten at high schools if chosen carefully.
Post by: hartiberlin on September 14, 2006, 08:37:32 PM
Quote from: raburgeson on August 03, 2006, 05:07:11 PM
Hmm, are you saying the heat came from the ground or from the sky above you at night ?
Hematite is said to release huge amounts of heat, if microwave
energy is put on it.
Maybe it also attracts at night some other radiation and converts
this to heat or otherway around it releases stored heat energy at night ?
So did the heat come from the ground or  the sky ?
Post by: raburgeson on September 15, 2006, 08:27:46 PM
The heat came from the sky, I am sure, and at one o'clock in the morning it just doesn't make any sense. Also noticed just after posting things cooled off around here and my computer started to run cooler. Things are going back to odd though and my computer is running with a core temp. now that requires me to turn the 20" box fan I have against it on again (I haven't had the cover on this machine since I bought it, but I was able to run it for a couple of weeks without turning on the fan right after the post.), something the government is doing probably. Otherwise why would posting info seem to help. Could they be doing something to cause this global warming?
