Poll
Question:
Is this the daumest thing ever?
Option 1: yes
votes: 1
Option 2: no, but almost.
votes: 4
Option 3: no
votes: 2
The patent numbers are 7770389, and 7877995. The patents can be viewed at the United States patent office.
Quote from: brian334 on July 31, 2011, 04:48:55 PM
It has already been discussed here - won't work.
Airstriker,
What won’t work?
Has the U.S. patent office ever issued a patent on any other invention posted at this forum?
My inventions are patented be the U.S. government.
as has been pointed out many times a patent is a legal protection only.
it is no indication of the workability or usefulness of the invention.
fritznien
The PTO will not issue a patent on a machine that can not work.
Quote from: brian334 on August 10, 2011, 05:39:13 PM
Not true at all. They do it every day. It is only for the protection of intellectual property, nothing more. If something works, or not, is not part of the equation.
PS If you look hard enough, you will find patents on "teleporters" a la star trek yet try to buy a working model.
But they issued your patents, and we all know your weather-making machines cannot work. I am confused.
It’s a good thing the PTO is not confused about what is patentable.
Machines that can not work are not patentable.
Quote from: brian334 on August 11, 2011, 06:23:51 PM
Here is a quote of just one of many patented devices that have been since proven not to work:
"In 1999, Sanjay Amin of Youngstown, Ohio, established Entropy Systems Inc. (ESI). The company received a 3.5 million dollar investment for a device that is claimed to violate the second law of thermodynamics, producing power by absorbing heat from atmospheric air (and that external reservoir can be at any temperature, even sub-zero). The technology had been patented in the United States, Europe, and Australia. The claims have subsequently been shown to be false and no product was ever released."
Note that the device received patents in 3 different countries.
Many, many other examples can be found here:
http://en.wikipedia.org/wiki/History_of_perpetual_motion_machines
This happens all of the time.
gs
Quote from: brian334 on August 11, 2011, 07:34:18 PM
gs
So, did you read about all of those patents of devices that never worked? I just didn't want you to misunderstand what obtaining a patent really means, and what it doesn't mean.
They also grant patents on devices that require technology that has not advanced enough at that time to produce it, which I find very interesting.
Bill
This is a patent announcement for people interested in gravity powered machines.
1
b
bs
This explains everything.
Brian334
Do you have a build of proof yet? Without the build, even a patent is just words.
The two black lines help
10/28/12
Quote from: brian334 on October 28, 2012, 07:58:14 PM
10/28/12
Hi brian,
congratulation for you granted patents.
1. Your comment above is little bit too short to understand (maybe only for me) ;)
2. I think a invention has two steps. 1. a granted patent 2. a working model with an independent validation. (in case of technical problems I am satisfied with a photo). I looking forward to see films or pictures. Thanks and good luck :)
Again I will repeat, this is only a announcement of two patents being granted.
3/26
Where can we read the above patents?
Quote from: telecom on March 26, 2015, 10:43:05 PM
On the screen of the same computer you used to post your question.
Using
Google Search, search for
us patent 7770389 and repeat for the second one.
Welcome
CANGAS 158
Thanks,
reading the patent 7770389 and really enjoying the smart idea!
Congratulations ! I thought about some kind of such device in the past . Kind of empty piston filled with water and emptied , moving in tight pipe with container below.I imagined a valves econtrolled electronically to empty such piston through the hole in the wall to the second container. Unfortunately I was looking for useful device for common Joe not for big converter of gravity.
Quote from: madama on July 15, 2015, 11:37:10 PM
hi
so i it overunity?
any demonstration ?
Except for the physical shape / appearance,
This device is exactly like the B-Units (Buoyancy Units) we developed in the 90's.
If properly designed, this device will operate as intended.
Is it "overunity"?
Absolutely not. This is a gravity converter. It takes gravitational force and converts it into work over distance.
Does it convert more gravitational energy than it uses to change buoyant states?
I'm not sure at this point in time. Physics says "no". They claim you cannot get out more energy than it took to change buoyant states.
but I'm having a hard time finding any definitive sources of information on this subject.
Changing buoyant states can be done many ways, with many variables and there is little info on how much energy is required to do so.
The energy obtainable from buoyant force, over distance, is well known. We have standard equations for this.
What I have NOT found, is any scientific source providing a comparative experiment showing the two energies side by side.
I am designing such an experiment, and whatever the results, I will post it here under a new thread.
I think that information is what we require to answer the buoyancy question once and for all.
The experiment will use the buoyant force, directly, to change the buoyant state.
With measurements of force from both the buoyant state, and the transition state.
This will be done first with Air and Water.
Then again using a denser fluid, and a gas with a higher coefficient of expansion.
this will allow us to establish both a baseline value, and some conversion data, to develop a general equation.
Quote from: CANGAS on March 27, 2015, 11:11:57 PM
Using Google Search, search for us patent 7770389 and repeat for the second one.
Welcome
CANGAS 158
Or save yourself hassle and go to
http://pat2pdf.org
The US patent office is a pretty shoddy place. If a patent has been accepted by the EPO, then that means something more.
Quote from: Paul-R on July 16, 2015, 10:28:03 AM
http://pat2pdf.org
I really don't see how this idea can work. the problem is that on the depth, for example, of 1 meter, the water pressure is .1 atm, which requires a considerable force to overcome.
On the other hand, there is no much force available because the device only works by the difference between sinking and floating, which is not that much.
what do u think?
hi
so i it overunity?
any demonstration ?
Answer to question number one: No.
Answer to question number two: No.
I hope this helps.
Bill
This is so daum.
I don't understand why the patent office would issue a patent on something that can not work.
It is the income they take from the patent fees, renewal fees etc what counts for them: such system insures a sure and regular sum... nothing else counts any more. And this is also country specific. And they do not ask for demonstrating a working prototype either, and this was not obligatory already in the last century either. (the "No model' statement is very often seen in the 1870 or later patents). Surely there can be other "rules" which if are met a patent is granted.
if reading patents recorded from the begining (i think 1830), starting with the very 1st us pat 1, formulae is "I do hereby declare the following to be a full, clear, and exact description of the nature, construction, and operation thereof".
something changed meantime and bocome something like " it may work that way, or that way.etc".
to be on topic , few years ago I made small toy , as attached , and behaved very surprising , yet not in disagreement with present physics.
cylynders were made of aluminium tube recovered from shaving foam spray
between the cylinders connected a flexible tube, abt 3mm diameter and end of each tube connected to a small flexible baloon(no matter the collor :)) and made fast to a rigid bar that turn around pivot point.
fill with water till abt 100ml into one baloon only and full pipe, another baloon squezed till no air remain in the system and then seal.
the "piston " were made of lead weights , may be a 50g, both the same, glued to a round washer that just pass nicely inside cylnder and glue also on the baloons.
initially the system is as per continuous line drawing, obviously the heavy part in right side dawn.
G1 start to move down and pushes thw water up , G2 is also comming down and create a slight vacuum , helping water even more to rise.
if you hold the system locked,full water transfer will be completed and releasing the system will rest somewhere the dotted line is.
to continue with rotation is needed to bring g2 where G1 was .
I've only made one set at that time and forgot already about it, may worth to try a bigger scale with more connected arms.
even IF will work, cannot say that is perpetuum mobile, still need the gravity to work, right?
about "converting" , not sure is the proper way of saying, earth will loose nothing gravity wise
There is a difference between something that might not work, and something that cannot work. As I understand patent rules they will not issue a patent on something that cannot work, so therefore the patent office must think this might work.
it's kind of like a feather and a brick, they both fall at the same rate in a vacuum.
Have you tried it?
Does it actually work?
I've done some calculations, it may work if at the top it compresses a constant force spring, which is being released at the bottom.
This will create a surplus of the buoyancy, which can be converted into the extra work.
Quote from: telecom on April 04, 2019, 12:22:18 PM
Only will work at the minimal speed of 2 m/sec in each direction.
This is not possible for this device in water, unfortunately.
it has to do with a feather and a lead weight falling. they both fall at the same rate in a vacuum, or in water if they fall in a continuous column inside a container.
Can you explain some more?
Glad to hear from you!
Quote from: telecom on March 10, 2020, 10:06:54 PM
https://www.youtube.com/channel/UCU8Oid56xktO9aNmZAceZdw
have you tried it?
Some food for thought,
I fully agree with newton but you can tap it internally and thus do the opposite of it if you tapped it external.[/size]With energy opposites like north and south or positive and negative thus there are two opposites one internal and one external so yeah.Inertia was best explained by Sir Isaac Newton in his first law of motion. Basically, the law of motion is that an object at rest stays at rest and an object continues in motion (self running) until an external force acts on it.
Self running gyroscopes demonstrate self running Inertia this already has been proven in science.
So if you don't tap it internally it wont work because of newtons inertia first law effect, it is the same as if you tapped the self running internal effect via external methods thus won't work, so you have to tap it internally and thus will work as in getting what you want real power/torque manifest to power a load whilst self running in that fashion.
So it you try to tap earths momentum of spin mass via external it won't work, it has to be done internally.
So the process is internal and the energy extraction bit is internal again and thus will fully work, so in world of energy there is positive and negative, same with internal or external energy tapping methods you get the idea.
The earths self running process and how it manifest spin torque which powers the oceans wave wind etc, the earth does that via internal methods of self running, because the internal mass of the earth is active and can get useful work/torque from it, it you tap it with a gyroscope which taps it in a internal way.
It is clear to me that this won't work as others have said because it is externally trying to capture the energy, so try the opposite method which is internal with a self running gyro scope, both opposites one external (won't work) or internal (will work), just like the opposites of negative and positive in the energy world the like or with electric so there you go.
So internal to internal regarding self running and energy tapping both internal processes.
The internal process is inside of the centre of gravity and external is outside of the centre of gravity so if you push the centre of gravity to get it to self run you will get two complete opposites of energy manifests regarding inside or outside the centre of gravity, outside of centre of gravity will never work and inside of the centre of gravity then mission accomplished.
I have seen several of your posts where you talk about self running gyroscopes. Where have you seen a self running gyroscope? All I have ever seen used an external force to keep them spinning.
gravity is a energy source, you just have to figure out how to make it work both ways. Up and down in a liquid.
Electric (pump)- motor with 90% efficiency x electric liquid flow conversion generator with 90% efficiency = ?
The same principle + siphon advantage ( co-/ad-haesion forces)
The same installation with low friction wheel
Heron's pump/siphon maths ncluded ! + the here propagated DIY " water motor"-kit
The only thing I can come up with is a compression spring on top of the movement.
This spring is being hit by the weight and compresses, but when the device
reaches bottom, this spring expands, and helps overcoming the water pressure, This allows piston to expand, and device completes the cycle,
Revisiting this idea again, and now thinking it will work, since there is no limit to the intertial force which is proportional to the mass.
Basically, on the way down we can have mass as big as needed to overcome the water pressure, and on the way up it can be balanced by the flotation.
Does the author belong to this forum?
Yes
I ordered some cheap micro-precision bearings from china
Apparently they had missed a decimal, instead of 1/4" bearings
i ended up with 200x 0.025" fit 5 across your finger $@&* if you drop it
Anyways, on any size wheel the torque between the shaft and the wheel is stupid at even low rpm
Almost a pure translation of momentum
and trying to stop it at the shaft can present quite an anomaly
Rotary momentum is taken using the circumferential angular velocity and the total mass of the flywheel.
When applying Archemedian leverage to a finite point at the center
(mathematically speaking)
Torque approaches infinity
Like the reverse of spinning a top
Because of logic,
or at least because my mind though it to be a logical path....
The same should be applicable to gears
in the sense that any sizable gear fitted to a
gear of infinitesimal size,.......
Would produce near infinite torque
[edit] - and conversely near infinite rpm on the small side when driven
not limited to testing relativity and time dialation
but would require near infinite torque to drive it
If you imagine something like the 'drinking bird' that was allowed to go 360 degrees
(Dip under water and back around)
With a gas right at its' phase change pressure
like butane
a flywheel to give it momentum
And the generator from a needlepoint
at the center of rotation
Geared to a very large gear, low rpm very high torque
Make up for the low rpm by having hundreds of magnets
around the perimeter
Quote from: Pirate88179 on August 11, 2011, 06:45:08 PM
The downdraft energy tower works to some extent, based on cooling hot air to send hot air heated close to the ground upwards. There may be other things that work fairly well, but few if any of them have been patentable so far.
Please visit: https://emporium.quora.com/The-History-of-Perpetual-Motion-Machines (https://emporium.quora.com/The-History-of-Perpetual-Motion-Machines) for more ideas.
Added note: I am surprised there has not been more use made of the sponge or cloth absorbing water on a slightly angled plane concept, with the drip returning downwards on a ramp without the cloth.
The capillary engine works in a similar manner
Water drawn upwards by capillary effect drips onto a waterwheel
a great many capillaries would produce an 'artificial tree' water pump
As seen in the redwoods - this effect can extend upwards at least 1000 feet
