Hi guys how can I increase production with lawton circuit other than electrolytes?
Doing more cells?
Have you conditioned the cells first?
Yes I am continueing to condition the cells. I have four cells connected.
Instead of delrin one can paint them with other paint for stopping leakage?
Do not touch the cells at all. 1 not much HHO. 2 Dirty Brown gas. 3 Masses of HHO. The cells acquire a nano coating. If leakage is container, do not use water contaminants. Take precautions. Sudden production of HHO can blow your house up. Better to test outside till it is working. IE a garden shed with open windows. Or use an electric drier ventilator hose to vent to a safe area outside. Process of conditioning can take weeks. DO NOT TOUCH THE CELLS. Be careful. HHO is powerful. Be responsible for your own safety and everyone else's safety.
Quote from: a.king21 on November 13, 2011, 10:43:09 AM
Hi King21 thanks for your precautions. I condition the cell outside near my basement. The thing is if I increase more cells to my lawton circuit will I increase production? cause a guy told me that it holds to 2amp draw and this is true I noticed.
Thanks.
Yes it should increase production but you have to watch for the water heating up. If it heats up too much you could lose production. At the point of maximum production there will be a current draw drop and plasma will be produced. It is actually cold fusion if you want to develop it. The process is still only COP> 300% however as at presently configured. If you are using the phase locked loop circuit it can go to 6 amps but again watch for water heating up. It is not recommended to push the system. If you want more output, better to just make a separate system. 6 cylinders is the maximum recommended but your output could actually drop. The problem is the ions are magnetised and don't want to move. Some people have experimented using magnets to shift the ions. Make sure your cylinders are in resonance. Good luck.
Hi King thanks for the info. I am using two chambers right now connected to one outlet.
Ok so I should increase more cells than.
