Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: gammarayburst on January 16, 2012, 08:34:50 PM
Title: Rotary Recipricating Pseudo Solid, LaFonte Group
Post by: gammarayburst on January 16, 2012, 08:34:50 PM
You should be able to figure this out from our last design post, but I will post operational description tonight.
This is one amazing machine!
Thanks,
Butch
Title: Re: Rotary Recipricating Pseudo Solid, LaFonte Group
Post by: void109 on January 16, 2012, 08:44:42 PM
It looks like it will take mechanical work to get the magnets rotated from step 4 back to step 1.
Post by: gammarayburst on January 16, 2012, 09:20:14 PM
Quote from: void109 on January 16, 2012, 08:44:42 PM
No, not at all, except for a slight amount for the lower magnet, operation description below.
Also our video showing pseudo solid testing. I will post link to refresh everyones memory.
Thanks,
Butch
Title: Operation description
Post by: gammarayburst on January 16, 2012, 09:21:49 PM
Note: The top assembly is stationary except for the rotor that can operate turning clockwise or counter clockwise. The lower assembly moves up and down like a piston. 1 shows the lower assembly being pulled to the upper assembly by the power of three magnets. 2 shows lower assembly flush with upper assembly. 3 shows rotor has rotated to the vertical position. This puts the lower assembly and upper in a neutral or even a repulsion mode. 4 shows the lower assembly moved to it's lowest point. 5 shows the rotor turning to the horizonal position and work is needed to remove it from the lower assembly but most of that work is recovered when the magnet is attracted to the upper assembly. 6 shows the lower assembly being pulled with the power of all three magnets. This is the start of repeating the cycle. The pull of the three magnets would be extremely strong as you can imagine.  Also a .005" air gap is between the pole of each magnet and the plate surface so our Pseudo Solid principle will work with no drag on the magnet due to friction.
Thanks,
Butch LaFonte
Title: Optional two magnet design
Post by: gammarayburst on January 17, 2012, 12:09:38 AM
See attached drawing
Title: Optional two magnet drawing
Post by: gammarayburst on January 17, 2012, 12:10:42 AM
See attached
Post by: Cairun on January 17, 2012, 06:31:25 PM
Hey Butch,
This is amazing work! However, I do see a sticky point in step 5 when the magnet tries to exit the moving block.
I may be wrong.  If I am, please enlighten me.
Best regards,
Cai Run
Post by: gammarayburst on January 17, 2012, 09:07:57 PM
Quote from: Cairun on January 17, 2012, 06:31:25 PM
Hey Butch,
Best regards,
Cai Run
Yes it will cog but then it will be pulled to the upper fixture to recover most of it. Also if the two magnets each have 100 units each of positive work available during the pull up phase on the piston assembly, then if the magnet does 100 units of negative work in step five then there is a 100 unit positive work available for useful work. Not mention the positive work done when the piston is repeled from the upper assembly.
Thanks for the comment,
Butch
Post by: Hayes-Eng on January 17, 2012, 10:06:32 PM
How can it produce EMF?  What is the operation principle?
Post by: gammarayburst on January 17, 2012, 11:46:00 PM
Quote from: Hayes-Eng on January 17, 2012, 10:06:32 PM
Our rotary version can be connected to a conventional AC generator. The basic operation is described above. It works on a principle our group (LaFonte Research) developed. We named it "The Pseudo Solid Principle"
Butch LaFonte
