Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: gammarayburst on January 25, 2012, 03:59:49 PM
Title: Declaring New Magnetic Science, Pseudo Solid Magnetics, LaFonte Group
Post by: gammarayburst on January 25, 2012, 03:59:49 PM
Nine years ago while doing research for a way to extract energy from magnetism I thought back to my forth grade school days and how I was intrigued at how a magnet on a metal file cabnet took work to get it off the cabnet but that it would slide up and down the cabnet side with very little effort. I wondered during my research if I could somehow use that sliding to get free energy from magnetism. After testing and posting video's to the web and to Youtube when it came on line I needed to give this principle a name. I came up with and was first to coin the phrase "Pseudo Solid Magnetics". I called it that because the principle uses magnetic field conducting materials that number two or more to form what in effect cause the magnetic source, permanent magnet or other to behave as though it was moving through a solid material not two or more. The pieces are placed flush so that the field moves from one piece to the other in a smooth transition with no drag increase, or work needed to move the magnetic source as you would when moving to an air gap or material not as conductive to the magnetic field. Also I found magnets placed with field conductors such as steel at each pole could move away and toward each other without the repulsion or attraction force coming into play as compared to moving the same distance across an air gap or other gap that was less conductive than the steel. I posted and still have many video's of the testing on Youtube. It has opened up we in the group believe a way to control a magnetic field in a way that allows for the extraction of energy from a magnetic source such as a permanent magnet that has as a positive energy net result. Some refer to this as "free energy". We are finding many ways to experience this with different designs and will continue doing research to find the most practical and efficient way to configure an operating system. We are changing our name to
LaFonte Pseudo Solid Magnetics Research Group. I used the term Pseudo because it is a material that for practical purposes appears as one
piece but is made up of two or more pieces but allows the magnetic source for practical purposes to interact with the material as though it were a single, solid piece. I have attached an example of one simple cycle we are working with now. We are also working on a closed loop system where the magnets never enter into an air gap during the cycle and will post today or tomorrow. Note: The magnet poles need to have an air gap between the magnet pole surface and the conducting material to eliminate drag due to friction between the two surfaces.
We have been using .005" in our tests. Will keep you posted.
Thanks,
Butch LaFonte
Title: Another sequence to help understand
Post by: gammarayburst on January 25, 2012, 05:14:30 PM
See attached
Title: Repeater Sequence
Post by: gammarayburst on January 25, 2012, 05:59:20 PM
See attached
Title: Color Coding Correction On The Magnets, Sorry Working To Long And Hard
Post by: gammarayburst on January 25, 2012, 07:39:40 PM
See attached
Title: Re: Repeater Sequence
Post by: gammarayburst on January 25, 2012, 07:41:55 PM
Quote from: gammarayburst on January 25, 2012, 05:59:20 PM
See attached
This has a color coding error on magnets, I corrected it and the new post is below.
Sorry,
Very tired, Butch
Title: Rotary Orbit Pseudo Solid Design, LaFonte Group
Post by: gammarayburst on January 26, 2012, 10:14:09 AM
See attached
Title: Rotary Orbit 2, Pseudo Solid Magnetics, LaFonte Group, Really Cool Machine
Post by: gammarayburst on January 26, 2012, 03:10:09 PM
This is one neat machine! Rotor assembly orbits between two outer disks and causes inter disks to orbit center axis. Pseudo Solid effect eliminates drag on rotor.
See attached
Title: Adjusted Center Axis Lines
Post by: gammarayburst on January 26, 2012, 03:39:23 PM
See attached
Title: Push Up-Pull Down, LaFonte Research Rotary Design
Post by: gammarayburst on January 26, 2012, 10:49:13 PM
This is a small section of a ring that is part of a rotary design.
Butch LaFonte
Title: Have We for Sure Found A Way To Get Free Energy From Magnets?
Post by: gammarayburst on February 02, 2012, 01:48:24 PM
 In A the magnets are pulled in.  In B the plates are pulled together.  In C the magnets turn 90 degrees and separate the two plates by repulsion.  In D the air gap is filled by the bar and it is actually pulled in forming a pseudo solid.  In E the magnets are removed from the plates assembly.  In F the cycle is ready to repeat but in the opposite direction.  Thats 4 positive work cycles and 1 negative.  Butch See attached drawing
Title: Re: Have We for Sure Found A Way To Get Free Energy From Magnets?
Post by: Low-Q on February 06, 2012, 07:07:37 AM
Quote from: gammarayburst on February 02, 2012, 01:48:24 PM
It seems to me that the bar in D is not pulled in, but instead repelled/prevented to enter the gap. If the two magnets had opposite polarity, the bar would be pulled in (Like approaching an iron piece into the magnetic gap in a speaker magnet). In this case the iron bar would be attracted to the sides, but prevented to enter between.
Have you tried this in practice - just to see what happen in phase D?
Vidar
Post by: gammarayburst on February 06, 2012, 04:21:29 PM
Quote from: Low-Q on February 06, 2012, 07:07:37 AM
Vidar
Yes we have tested that it does get pulled in.
Butch
Title: New Pseudo Solid Design
Post by: gammarayburst on February 06, 2012, 04:42:00 PM
See attached
Thanks, Butch
Title: Re: Declaring New Magnetic Science, Pseudo Solid Magnetics, LaFonte Group
Post by: dradak1 on February 06, 2012, 08:11:03 PM
Quote from: replaced on February 06, 2012, 07:42:45 PM
The first law of thermodynamics says that energy cannot be created or destroyed.  End of story.
Anyone who thinks otherwise is WRONG.
Why do you think that after 500 years a free energy machine still hasn't been invented yet?
I can tell you already that without looking at these magnets, that they will NEVER produce ANY over-unity.
And the Earth is flat - period.  ;D
Post by: Low-Q on February 08, 2012, 05:12:34 AM
Quote from: dradak1 on February 06, 2012, 08:11:03 PM
No. The earth is round - like a pizza ;)
Post by: Low-Q on February 08, 2012, 05:23:21 AM
Quote from: replaced on February 06, 2012, 09:52:36 PM
Saying that free energy machines won't be invented is not just an assumption like the world is flat.  How is saying that over-unity is possible is any different than saying that the world is flat?  There is overwhelming proof that the world is not flat and that over-unity is not possible.
I can agree with this. We all do work with numbers. As long 1 equals 1 there will be no overunity. If we can find that 1 is less or greater than 1, like comparing two apples of different size, they are 1 each but in different size. That is the kind of numbers we must look for. No one has found these numbers - yet.
We know that the earth is not flat, and we know by looking at OUR history that over unity is not possible. The history before that let us know that energy once occoured - energy is present now, so from where did it came from?
In order to create energy, we must create a potential difference - by applying energy = no point. Potential difference is the reason we have energy today, but the universe - the whole system - is so big and slow that we hardly notice that the potential is approaching equilibrium - into no energy. Humanity will most probably disappear long before the energy in the universe is gone. So fighting against physics in order to create more and new energy is no point when we can harvest the already existent energy for free the next 100 billion years or more.
Vidar
Post by: Cairun on February 08, 2012, 08:17:54 PM
Quote from: Low-Q on February 08, 2012, 05:12:34 AM
Aw... I thought it's square
Title: Animation and drawing of super simple Pseudo Solid Rotary design, LaFonte Group
Post by: gammarayburst on February 09, 2012, 07:56:10 AM
See attached,
Thanks,
Butch LaFonte
Title: Drawing of new design to go with animation
Post by: gammarayburst on February 09, 2012, 07:59:03 AM
See attached
Title: Mono-Directional material for Pseudo Solid designs, Lafonte Research
Post by: gammarayburst on February 10, 2012, 12:03:45 PM
See attached
