Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: alienas on February 27, 2012, 06:48:24 AM
Title: Some help needed to do a Bedini generator
Post by: alienas on February 27, 2012, 06:48:24 AM
Hi there, i'm new to this forum ;
I'm 45,  i've got some physic skills because i've been 4 years to highshool learning physic. But it's a long time so i've forgotten a lot.
Any way i would like to build a bedini generator starting with one coil only and i've anderstood more or less the principle but i would have a lot of questions, about how to get the parts, for instance,
are you agree to help me ?
First what coil must i use, do you do it yourself, with what gauge of wire to use ?
I've got some N52 magnets, is it too strong ?
Thanks in advance
Eric
Title: Re: Some help needed to do a Bedini generator
Post by: Low-Q on February 27, 2012, 02:13:59 PM
Doesn't matter the grade of the magnets except the required torque to run a generator with strong neo magnets - and except the thickness of your wallet N52 neos aren't cheap.
What will you run your generator with?
Vidar
Post by: alienas on February 27, 2012, 03:22:02 PM
Thank you for answering !
I'm not sure to anderstand the question correctly. I'm french !
I would like to realize a model with a cd rom spining on it's motor with 4 magnets , one double coil at one point only, and 12V battery, the load would be a light ... And see how many volt i generate. In the close future, i would like to get 230 V 50 Hz alternative voltage  ;)
Eric
Post by: Paul-R on February 28, 2012, 06:44:51 AM
This group is outstandingly good on the Bedini. Nothing comes close
in this particular field:
http://tech.groups.yahoo.com/group/Bedini_Monopole3/ (http://tech.groups.yahoo.com/group/Bedini_Monopole3/)
Post by: mscoffman on February 28, 2012, 01:24:37 PM
Quote from: Paul-R on February 28, 2012, 06:44:51 AM
@all,
I was going to post this link, but Paul got there first. I agree completely with what Paul
has said and wanted to add a few additional comments. This group expects you to build
a bedini machine pretty much identical to their standard version, then encourages you
to take data until you get results similar to what they have! This is a unique approach
and an (almost) scientific way to understand it. What they refuse to do in this group
is to discuss theory(ies) of operation or extensions or upgrades to their standard
device to make it useful.
Overunity in a bedini machine is a tough nut to crack apparently, and requires significant
tuning and experimental time, so what they provide is a firm basis for doing that.
:S:MarkSCoffman
Post by: Low-Q on February 28, 2012, 02:14:58 PM
Quote from: alienas on February 27, 2012, 03:22:02 PM
Eric
What I ask is what kind of source wil you use to run the Bedini generator. Waterfall, Sun, diesel engine, electricity?
Well - I assume you know that the Bedini generator doesn't run by it's own power.
Vidar
Post by: alienas on February 28, 2012, 03:07:31 PM
Quote from: Low-Q on February 28, 2012, 02:14:58 PM
Vidar
OK i got it ! With electricity, with a battery. I would like to do just a little experiment to begin. I don't know how to do my coil exactly, i saw some without core in the center, that were working. And what size of wire and number of turns, does it depend of the grade of the magnet, or may i follow exactly the bedini's shematic whatever magnet and wheel i use ?
Regarding the bedini monopole 3 website, they seem to be a little too extremist for me. I don't want to use a bicycle wheel for instance...But it can be helpfull. I hope i will find help here !!
Eric
Post by: mscoffman on February 29, 2012, 03:09:02 PM
Quote from: alienas on February 28, 2012, 03:07:31 PM
Eric
Aye, that they are. But if you do borrow something from them you have go to
believe it will be exactly specified. They even give directions for winding the coil
so that it results in the correct connection polarity.
:S:MarkSCoffman
Post by: Paul-R on March 02, 2012, 12:55:08 PM
Quote from: mscoffman on February 28, 2012, 01:24:37 PM
Yes, but when you have built the device in the Bedini_Monopole3 group, you will
be admitted to the No. 2 group which does explore further. There is a No. 1 group as well
